Ball Bearing Turbo Conversions
Yeah, there's a bit of misinformation out there with the turbos.. some good sources say it is not titanium shaft, others say it is.. since I already have a complete turbo, I'm not inclined to take it apart far enough to be able to see that part and verify which it is..
Originally Posted by EVOeight
Couldn't you just stick a strong magnet on the shaft and see if it is steel or titanium? Steel is magnetic and titanium isn't?
At this point, anyone working with modifying a stock turbo, or using an upgraded or hybrid stock style turbo is experimenting, so nobody's really certain what the results would be.. With a smaller turbo, power is even more about the combination of parts you choose.. For me, It will be good head work, and additional displacement (2.3 or 2.4 liter stroker short block) and getting as much air into and out of the engine with the lowest restrictions.. In other words, making similar optimizations that you would make for an NA engine..
It certainly may not be the cheapest way to go, but I'll gamble that its probably going to make similar power to any other option, with much better drivability.
MalibuJack, do you think the stock turbo will not run out of steam on a 2.3ltr strocker? i ask because Ralliart offer a 2.3 ltr strocker for stock EVOs over here and they only get 340bhp out of them! i personal think that you will be pushing the stock turbo beond its limits if you want any decent kind of boost. and what about back presure from the (relativley for the engine size) small exhaust housing? what are your thoughts???
have you thought about increasing your comp. ratio? this will give you more torque acroos the whole ranage and give you bettter driveability!
apart from that it seams as though you will have a cool set up. my only concern, as already said is the strocker!
thanks Chris.
thanks Chris.
Originally Posted by marksae
Higher compression ratio will give you better off-boost power and better gas mileage, but will limit the amount of boost you can run on pump gas.
thanks Chris.
thanks Chris.
guys, i am really sorry i have to do this but since this entire thread is made by an illegal vendor and a banned member i have no choice but to close it down. i will leave it up but closed so people can use this info and hopefully he will become a vendor here so we can have this great option.
thanks
Snir
thanks
Snir
FS[Mid-Atlantic]: Garrett gt35r t3 ball bearing
Voltexed
Oct 20, 2016 06:30 PM
WTT[South]: 6262 Dual Ball Bearing for trade. I need a 5858
hfj8080
Oct 24, 2015 04:55 PM
teddy
Jul 6, 2004 01:43 PM
ez76
131
Jul 1, 2004 03:51 AM
ball, bearing, bearings, brg, conversion, conversions, convert, converting, cost, cosy, essex, kit, titanium, turbo, turbocharger
