Intercooler Upgrade Jerking at 5k at WOT
Old Jul 24, 2004 | 03:09 AM
  #31
trinydex's Avatar
malibu jack's post said it was his boost controler, you have a boost controler in yer mod list.... is that the problem? does your mbc spike? and if so is that what's making you run lean at that rpm?
Old Jul 24, 2004 | 05:46 AM
  #32
MalibuJack's Avatar
Nah, I didn't say it was his boost controller, I recommended dropping the boost to see if it was a boost related misfire.. Although it could be a lean spot, I'm more inclined to believe at the moment its probably worn out plugs.. Although that is a good point since I did have to add fuel with some of the aftermarket components I had.. With the S-AFC (at the time I had one) I had to add +2 or +3 fuel from 2800-4000rpm or so.. not really at 5000 but some cars could need a bit (depending on the aftermarket components)
I think its always a good idea to change your plugs first when you experience stumbling or a misfire simply because the plugs just don't last very long under high boost on these cars. PLUS you can read your plugs to see if its too rich or too lean (In general)
Old Jul 24, 2004 | 02:27 PM
  #33
TD05HR's Avatar
i'm pretty sure its your boost cont. i had the same prob..i install one that i made..seems to be ok if i gradually step on the gas...but if i do WOT on any gear it bogs out..so i replace the BC and everything is fine now...gl man
Old Jul 24, 2004 | 05:24 PM
  #34
boostedwrx's Avatar
sounds like a boost leak...
if u do get plugs, get some HKS S40G's, heat range 8 and its the last plug u will ever need
Old Jul 24, 2004 | 10:11 PM
  #35
ArchieBabes's Avatar
Problem solved, I just installed back my stock IC pipes and got rid of the Greddy Lower Intercooler pipes.
I also changed my plugs to the NGKBP8ES, I have another question in tightening the spark plugs, I just tightend mine by hand by using the extension wrench.
Old Jul 24, 2004 | 10:27 PM
  #36
kuniboy's Avatar
uh.... well, what is the problem??? Tighten the spark plugs about 1/2 turn - 3/4 turn.
Old Jul 24, 2004 | 10:43 PM
  #37
Evolution7GSR's Avatar
its fuel cut i have it too!!!!
Old Jul 24, 2004 | 11:40 PM
  #38
Evolution7GSR,
Its not fuel cut, I think boost is leaking.
I got it fixed by returning the stock lower ic pipings.
That fixed the problem at WOT
How do you know if you installed the Spark Plugs wrong, or not tightened enough? What will happen?
Car seems to run fine, by just tightening the Spark Plugs by hand via the extension wrench.
Old Jul 25, 2004 | 12:18 AM
  #39
trinydex's Avatar
there are torque specs for spark plugs aren't there? car might run better because the plugs are oriented the "right" way, if you direct them a certain way your car will run more efficiently cuz the spark hits the fuel in a better way.
Old Jul 25, 2004 | 07:14 PM
  #40
kuniboy's Avatar
i think you might have left some packing plastic in your IC piping. double check the intercooler and the piping for plastic or paper lodged in it.
Old Jul 25, 2004 | 08:53 PM
  #41
MalibuJack's Avatar
Did you try just changing the plugs first before removing the pipes? I am curious to know if that helped any since it solved my problem..
Old Aug 2, 2004 | 06:50 PM
  #42
EVO8LTW's Avatar
Plugs should be 18 ft-lbs, give or take 4 ft-lbs.
shane_evo7
Nov 11, 2016 09:23 AM
Windstorm
Apr 23, 2012 05:59 PM
feimax
Apr 23, 2011 08:30 PM
mirXa
Aug 30, 2010 11:57 AM
X_Evo
17
Nov 11, 2007 06:39 PM
