how do you install spark plugs?? (HELP)
Old Jul 26, 2004 | 08:05 PM
The Emperor's Avatar
could anyone give me a write up on how to install spark plugs...thanks
Old Jul 26, 2004 | 08:07 PM
1QWKEVO's Avatar
isn't it kinda self explanatory? Remove the spark plug cover, remove the coil packs, remove the plug wires, and remove the plugs... then reinstall in reverse.....
Old Jul 26, 2004 | 08:09 PM
um.. what are the coil packs, and plug wires??
could someone tell me step by step? thanks
Old Jul 26, 2004 | 08:14 PM
UFO's Avatar
UFO
You know the plastic bit on top of your valve cover with Mitsubishi on it? Remove the 4 bolts/screws from that and lift it off. Underneath you will see your coil packs and wires. 2 coil packs, 4 wires. I think there's 3 bolts on each so undo those and lift the packs & boots out. You now have access to your 4 spark plugs.
Old Jul 26, 2004 | 08:16 PM
okai..you know those black things on top of each spark plugs?? how do you take them out?? just pull them or screw them??
Old Jul 26, 2004 | 08:20 PM
UFO's Avatar
UFO
The black things are the boots for the plugs and they just pull straight up.
Old Jul 26, 2004 | 08:23 PM
1QWKEVO's Avatar
its prob best you not change them.... you may over tighten a bolt or loose something in the cylinders... not trying to be rude but i'm serious better safe then sorry
Event-Horizon's Avatar
hey, if you dont know what things are under the hood I wouldnt change them myself.
Old Jul 26, 2004 | 08:25 PM
yea thats true..its always good to learn though...im going to my mechanic tomorrow THANKS GUYS!
chmodlf
Feb 18, 2006 04:37 PM
clovis112
May 30, 2005 12:57 PM
gregivq
12
Jan 15, 2005 02:36 PM
The Emperor
14
Jul 18, 2004 01:22 PM
Static
Lancer Engine Tech
11
Oct 31, 2003 03:44 PM
