Installing new spark plugs = resetting ECU?
Old Oct 31, 2003 | 01:18 PM
Static's Avatar
I just had a question, i installed some new spark plugs, and it kinda seems like my gas milage is less then it was before, and they were supposed to increase gas milage... Ive seen people say that resetting ecu fixes some stuff when new parts are installed... Is that something i should do? If so how do i do it? thanks.
Old Oct 31, 2003 | 01:24 PM
ghostrider's Avatar
You shouldn't have to reset the ECU. Check to make sure you plugs are gapped correctly (.43) and that all the plugs got reinstalled firmly.
Old Oct 31, 2003 | 01:50 PM
Static's Avatar
The ones i got were pregapped, should i trust that?
Old Oct 31, 2003 | 01:54 PM
.L.'s Avatar
.L.
they always tell me that too, but i double check anyways. there are always 2 that are off (when i changed them on my old car.... havent done it to the lancer yet though). you should double check just to make sure.
Old Oct 31, 2003 | 02:00 PM
Static's Avatar
I have the boshe (spelling?) pregapped platinum ones, they have 2 extentions on them if that makes sense... you know at the end of a normal spark plug it has the little metal peice that goes up wher eu set the gap, mine has one on both sides, if that makes any difference.
Old Oct 31, 2003 | 02:36 PM
Static's Avatar
bump
Old Oct 31, 2003 | 02:42 PM
.L.'s Avatar
.L.
oh ok you have the bosch... well i guess i'll let someone else answer this then. i've never used those plugs before. i always stick to the traditional single extention ngk's, or denso's.
Old Oct 31, 2003 | 02:49 PM
Archangelite's Avatar
oh man, i heard nothing good about bosch platinum to be used twith the lancer. the dealer told me that those werent good for the lancer. try denso iridium or NGK. another thing, is the driving any diff? i noticed when i changed mine that the shifts were a tad bit smoother. so maybe the gapping is wrong, or it is the fact that you used bosch.
Old Oct 31, 2003 | 02:53 PM
.L.'s Avatar
.L.
yeah they told me a LONG time ago that those were horrible for my old acura integra. so i naturally assume they wont be good for my lancer. i've always stuck with ngk and denso. good stuff you can count on.
Old Oct 31, 2003 | 03:02 PM
Static's Avatar
Bah! Wish i would have done more research first. oh well, i guess i should probably put the stock ones back in for now.
Old Oct 31, 2003 | 03:29 PM
kenny_omar's Avatar
Dude, same problem with the same sparks, poorer fuel economy and less power, must be the sparks. I'll have to change mine to.
Old Oct 31, 2003 | 03:44 PM
yup, its probably the bosch
infam0usndn2nv
Feb 7, 2016 12:09 PM
ffsman12
11
Jan 15, 2015 08:31 AM
nightrider
Lancer Troubleshooting
Dec 19, 2004 05:45 AM
pickleknock
49
Mar 23, 2003 10:53 AM
lancer02Josh
Dec 30, 2002 09:05 PM
