Check out my dyno pull, let me know what you think
im having trouble posting it, it seems the file is too large its 1.51 you can only post 100. or smaller. So i gotta find a way but for now i will fax over the sheets to al maybe he can post them.
Things happen, things can go wrong etc. We are dealing with cars and people here.
For the guy in Texas that picked up 50 whp from switching to TT tune it is extremely hard to believe. I am not calling you a liar in anyway as I am sure from the first time you dyno'd to the second time there was that much difference. I would be willing to bet that something else changed, as a matter of fact I would bet my left nut on it. Maybe an intercooler pipe got tightened, different manufacture of fuel (Sunoco one time, BP another, Quickie Mart another) or different octane. It is hard to compare one tune to another if you don't run the exact same fuel from the exact same gas station every single day and you then better hope that gas station is actually filling their 94 ocatne tanks with some real 94 each time. Too many variables.
One thing I know for sure, Al CAN tune EVO's. Yes, him and I are friends, but he probably wouldn't be if he didn't know how to tune. Quite honestly we became friends through tuning and he has proven to me over the last 2 years to not only be competitent but to also be a very passionate and honest guy, this makes us very similar people.
So, taking into consideration that I know that Al can tune an EVO I am telling all of you that there is NO way that there was 50 whp left in his tune compared to what Mark did for you. It just is NOT possible. There is only so much you can do with pump gas, the AFR's can only get so lean and stay together and the timing can only get so high. There is not that much of a margin left.
Now if you had some complete idiot tune your car and then had Mark tune it I would believe it. In this case or in any case of one qualified guy tuning and then having another one tune it again, it is just not possible.
Perfect example is my recent dyno testing with the AEM EMS in the car with the MAF sensor. After probably 50 runs of tuning I had a decent number. Al comes in and flashes the car, two more adjustments and the power level is the same as what I could muster up with the EMS and 50 pulls. I wouldn't suggest the EMS for anyone at this point unless you had quite a bit done to the car or needed the datalogging for some reason. The HP increase is just not worth the expense. Converting the car to speed density is another story and there is some power to be had buy loosing the MAS. I am getting off subject now, sorry.
Point is if you have 2 good tuners tune an EVO the numbers should be somewhat similar. 50whp tells me something else was going on.
David Buschur
www.buschurracing.com
David Buschur
Originally Posted by Evo_doer
When I switched from ****flash to Turbo Trix Flash. The only thing I added in mods were a MBC. HP change was ****flash 276.17 to Turbo Trix 294.91 Hp No flames ingnited
but the #s tell the facts.
Originally Posted by EVOTEXAS
Hey man, this is exactly what happened to me with a Dynoflash. I wasn't quite so low, more like mid 250's. I switched my flash to TurboTrix and hit 308. Both were mail ins, and when I got custom tuned by TurboTrix, I added cams and hit 340 (all on a Mustang).
Damn, I am glad to see someone else post about this. It really is hard to believe, but despite all the promises and marketing, the power isn't there (but there is a lot of safety in that tune, rest assured
Well I must say I concur with 4g63 icon Dave Buschur. Mark has experience with evos as does Al. I cannot see this much difference in a tune at that level. Something seems to be different, could it be boost that was different? 50HP is alot on a 300hp car.
Sean
Sean
Originally Posted by strongbear0
You added a boost controller and were able to hold boost till redline instead of tapering off. I would say that would be the cause of your extra 18whp and not so much the tune.
Hey guys - I am a guy who takes a LOT of pride in what I do, and I really enjoy my job of tuning evos. I live, sleep and **** evos 7 days a week, sometimes for 16 hours a day for days at a time. I have been all over the USA and back again dozens of times tuning every kind of evo you could imagine from road racers to rally cars. I am very careful and accurate with every tune I sell and in the case of Evotexas I drove and data logged his base flash personally and it was running fine when I installed it. It really bothers me to be reading these kind of constant and repetative posts by Evotexas claiming my product is crap and another one makes so much more power becuase I know the claims are false.
Evotexas's posts start to make me wonder what is behind all of this. I know there is no way that my flash can leave 50 whp on the table - its impossible. In reality the differnce between my reflash and the others out there is at most 15 whp between one to the other - WITH COMPRABLE mods. I have been very annoyed with this claim of Evotexas about this so called "50 whp" which he has been pushing now for months and months over and over again. I can only assume that he is out to try and discredit my product and promote the dyno days that he is organizing with competing vendors.
I finally have found the time to go back and search through some of his past assertions and try and probe deeply into his dyno tales and see where this missing whp is comming from.
I had to go through every post he made to follow his whp progression and figure out exactly what he has been claiming as in many cases his claims are contradictory and they change from day to day.
Mods - cat back exhuast, Hallman RX and walbro 255 lph pump with base Dyno Flash. I would have estimated his car at about 275 whp (dyno jet) at that time when I test drove it - just an estimate. This is typical with that level of mods and a stock down pipe and intake box.
MODS were - Megan Racing DP
Cat Delete
Custom Catback
HKS RS Intake
Hallman MBC
Walbro Fuel Pump
TurboTrix ECU Flash
Well - MORE mods - in this case a down pipe and intake and he is making an extra 20 or so whp - NOT all that surpizing. Later - we will read that at the time he was jacking up his boost higher than it should have been and had his timing pulling - detonation - to make this number. This could be a reason why the dyno sheet was never posted as it prob did not look very good.
BTW , Evotexas - did you know that it is customary for my customers to make far in excess of 292 whp with those mods on the Dyno Flash in fact 300 - 305 whp is not uncommon - unlike yourself who has never even posted one dyno sheet there are literally dozens upon dozens of my customers dyno sheets posted on these forums;
Here is a dyno verified example of what I am talking about with comprable mods
For further analysis of what kind of results we make with your then level of mods you can read about case study # 10 here - https://www.evolutionm.net/forums/sh...d.php?t=105468
Interesting that you neglect to mention the race gas which we find out about later . . . .
Interesting how you fabricate the Dyno Flash whp numbers from your "projections" and yet then you go on to post them over and over again for several months as if they were from a real dyno sheet
Evotexas - on September 23, 2004 you were making "over 300 whp" with the TT flash - but a day later you were making eaxctly "292 whp" - running a little bit rich - WHICH was it ? Or can you even remember considering that, ironically, there are no dyno sheets for any of your pulls.
So Evotexas it seems that your Dyno Flashed whp estimate is not an actual dyno number but rather a "estimate" that you fabricated based upon how much your friend pulled you on the highway. Maybe this can explain why you have no dyno sheet to back up your claims?
This was hardly accurate - was it - not the same exact bolt ons at all . . . . So - Evotexas what you are doing here is comparing a LOW BALL estimate that you derived from your street racing experiments of the power of my base flash with a stock intake and down pipe on pump gas and then compareing it to your car after a full 3" exhuast and a HKS RS intake were added on race gas - this seems hardly fair or honest to me.
WHERE are all the dyno sheets of all these pulls ?
WHY would you run MORE BOOST than "the tune called for" - were you trying to prove a point ? Did you also jack up the boost when you tested my dyno flash tune with your deadly acurate who pulled whom on the street testing method to concoct your 255 whp estimate ?
So - what you are telling me is that you were "pulling timing" in my dictonary - DETONATING on race gas. From my experience you really have to be PUSHING the tune to reach the point of detonation of race fuel. That means you are hardly running a safe tune or one that is making a good comparision to my through the mail flash which you stated above ran very "smooth" in your car and which was tuned for pump gas.
In conclusion - when you make a blanket statement that you have made "X" amount of whp more with one product over another product I would expect you to at least have a DYNO SHEET or quantifyable form of measurement to back you up.
Instead you have distorted the facts by making unfair comparisions between my flash and another flash with different modifcation levels on your car which accounted for the majority of the power gains, different fuel and a different boost level.
I think everyone can agree that to make any rational comparision between tunes you have to run the same boost, the same fuel and the same mods? Do you disagree with this concept?
I think you should be ashamed of your blatant, misleading and unfair slanderization of my product in an attempt to promote a competeing procuct. Especially when you are failing to disclose that you have recieved free tuning services from the competing tuner.
I would epect that inteligent and educated readers would look for a DYNO SHEET to verify these kind of claims before they accept them at face value.
Finally - when you want to compare two tuning products in an inteligent and FAIR manner - we use a dyno. This is what a comparision looks like
You can read all about how we test our tunes against other tuners and see the actual dyno sheets in the so called case study threads on the dyno flash forum.
It amazes me that to this date you still have not posed any dyno sheets to support your claims - - but then again maybe the fact that you have somehow lost all dyno evidence of your claims is not all that suprizing after all. Its easy to throw numbers about in an attempt to drum up some business for your pals. Obviously when there is no truth or substance to your claims there will be no back up documentation.
As an example of how you compare tunes - here is on of one of my exactingly measured case studies for those too lazy to do a search https://www.evolutionm.net/forums/sh...=101126&page=1
I am tired of this orchastrsted anti dyno flash marketing smear campaign where flase whp claims are thrown about in an attenpt to undermine and discredit all the hard work I am doing every day to make a good product. I find it very sad that some people are ignorant enough to accept these kind of claims at face value without further documentation or verification.
If you dont have a dyno sheet or time slip your fantasy claims have no merit in my book nor should any other rational person belive your claims.
The real life evidence at the race track with 1/4 mile times achived by my customers who are the fastest in the US with reflashes contradicts the idotoic whp estimates that thsi gentleman is trying to make
Thanks for anyone who has taken the time to read this garbage
See you on the dyno or track - talk is cheap
Whats up guys! I picked up Al from the airport and he flashed my ECU on the way to the hotel! Now everything is moving faster and running smoother! Man, it is worth it for Al to flash your ECU at ANY price! I am def. satisfied.
The two most noticeable things on my car were how much faster the revs got higher and how much smoother the car/engine was on the way up.
Posted by Evotexas May 22, 2004.
I put down 292 on a mustang (eddie current?). Posted by Evotexas August 31, 2004
Cat Delete
Custom Catback
HKS RS Intake
Hallman MBC
Walbro Fuel Pump
TurboTrix ECU Flash
Al, how's it going, man?
I am the guy that picked you up at the airport when you came to Dallas several (or a few?) months ago. You flashed my ECU on the way to your hotel.
Hey man, I was satisfied with my flash after you did whatever you did. It "felt" good.
However, I ran my friend with half the mods I have and he kept outrunning me in fifth gear horsepower runs.
I called you and you told me that my Hallman Boost Controller was bad. I found that to be an astounding over the phone - cross country immediate diagnosis.
I didn't change anything except for the flash to one from TurboTrix.
Now I pull HARD over the same friend with the same parts. And by the way, my AF ratio is just as safe or safer than yours. Below 11:1 in the majority of the RPM range.
I also put down over 40 more horsepower than said friend did when, before the change of flash, he was outrunning me in fifth gear on the highway. Posted by Evotexas September 7, 2004
How about if a guy with a Works flash and the EXACT same bolt ons as me, who dynoed 264 AWHP outran me when I had the Dynoflash.
Then (on the same day as the Works guy), after I reflashed with TurboTrix, I put down 292 AWHP (running rich).
Our run was a fifth gear highway run with no driver involvement. A true test of power.
He was faster so I had less than 264 AWHP.
So lets estimate I had about 255 judging by the rate at which he pulled on me.
So I gained about 40 AWHP by changing only the flash.
Now I have a revised flash from TT making it a little leaner up top. I am expecting another 20 HP. I will dyno on Saturday.
The dyno we use shows low numbers compared to a Dynojet (it's a Mustang AWD). I know this because I am a LITTLE bit faster than two Vishnu guys here WITH cams (I have no cams) on the highway and they dynoed 320 AWHP on a Dynojet.
Is that proof enough?
The only flash a Dynoflash is better than is a stock flash. Posted by Evotexas September 24, 2004
You're on the East Coast. There is no other choice than TurboTrix. I am making over 300AWHP with a TT flash and similar to you.
If they are absolutely not an option, go with an SAFC-II.
The Dynoflash is subpar over a wide comparison of products and users and it's pretty hard to deal with Al, IMO. There will be a few in between that like the Dynoflash but I don't think they know the difference. All they can pretty much confirm is that it works better than stock. Everything does at least that. Posted by Evotexas September 23, 2004
For instance, on a Mustang dyno, a 2 STOCK 2004 EVOs both dynoed in the 280's with just the Injen intake setup and NO tune.
A stock 2004 Dynoed 251!!
A stock 2003 dynoed 218!!
I dynoed 308. Posted by Evotexas September 30, 2004
Not only the dynos provide proof but also the fact that my friend who dynoed 264 AWHP (Works P2 and otehr bolt ons) continuously pulled me on fifth gear highway runs (no shifting - just HP) and we both fill up at the same place. After my new flash, before we went to dyno my car again, I started pulling him VERY hard on the highway (just as some non-dyno one time only type proof). It was the tune. If you have any other possibilities please let me know. This is not only surprising to me but it was also surprising to the guy with the exact same bolt ons as me with a Dynoflash that dynoed 276 on the same day I dynoed 308. I know there is some car to car variance but that is a lot. His username is Monkey. There were about 25 witnesses. Let me know if there could be other reasons negating all this "proof." I am just as interested as the next guy. I am only posting what I have seen. Thanks. Posted by Evotexas october 13, 2004
Hey man, I can't tell you what you'd make with your bolt ons but I had the same exact bolt ons with a Dynoflash and made HP in the 250's. I got a TT mail in flash and made 308.Posted by Evotexas October 23, 2004
I did NOT have more boost. I had LESS than 20 psi for the last two pulls. I did NOT have race gas until the LAST pull.
The second to last pull I made 296. That is 20 more AWHP with less boost, no race gas.
I made 3X more HP with some race gas added in and even less boost yet. Don't distort the facts. This is part of the problem most people have with you, Al. Posted by Evotexas November 18, 2004
So there is the proof you were running race gasI made 296 on pump and had the boost higher than the tune called for. I turned it down 3 psi and put in race gas and hit 308 because at 21-22 psi it was pulling timing. To say that race gas is what did it is a little bit hard to say. However, I am sure it added a couple HP. In fact, I started the pulls even higher boost than that and turned it down each pull. The power went up each time. My gauge may be off, I don't know for sure. Either way, the last time I turned it down was a significant lowering of boost and it went up 10 HP. It doesn't take a big change in boost/timing to make 10 HP. While I realize that there is a little bit of error invloved, even a 10 horsepower difference is quite small. The point of my story is that a 50 AWHP difference for the same product at the same AF level is not small. Posted by Evotexas November 17, 2004
I, for one, can't wait for my base dynoflash, especially since the "butt dyno" says my car is slow again...and after the flash I will be dynoing on the same Mustang dyno I did for my baseline...I'll have a tbe w/ catdel and the baseflash...then we can paint a pretty picture
