RedLine OIL
Old Feb 15, 2005 | 09:47 AM
RedEvolution8's Avatar
RedLine OIL
anyone using Redline oil? if so does it really control or removes some what turbo log? do u guys recomend it 4 our cars?
Old Feb 15, 2005 | 09:59 AM
Event-Horizon's Avatar
oil is not going to remove any of the turbo lag. Dont always believe what you read in magazines or hear from friends. Stick with what mitsu recommends, Mobil 1 is some of the best oil out there.
Old Feb 15, 2005 | 10:31 AM
calhoun's Avatar
i have there gear oil in my car and have always used redline in my past cars. Red line is one of few truly synthetic oils wehre mobil one is not. From what i remember they also guarantee a 1% hp increase just from changing your oil. Granted thats not a lot but still all you did was chang your oil.
Old Feb 15, 2005 | 10:34 AM
dryad001's Avatar
My Motul shipment should be in tomorrow. I never had good luck with Redline.
Old Feb 15, 2005 | 10:39 AM
My personal pref is German Castrol 0w-30....mmmmm green oil.....
Old Feb 15, 2005 | 10:40 AM
BrownPoop's Avatar
I had good experiences with Red Line oils in the past... their 'Water Wetter' product is also very good for turbo cars on hot track days.
Old Feb 15, 2005 | 10:44 AM
calhoun's Avatar
i would say try it on your next oil change if you dont feel a difference or dont like it go back to the mobil one. it isnt going to hurt anything to try it out, and its only a couple dollars more then the mobil.
Old Feb 15, 2005 | 06:01 PM
hutch959's Avatar
I thought mobil 1 was fully synthetic???
From what i understand mobil one is made by taking crude, breaking it down into a bunch of simple things (powders, liquids, .... you know, organic chemicals) and then put back together into the "oil".
I know other oils kinda go around this process and add non man made oils to man made chemicals and then they call it synthetic, but not mobil 1
Old Feb 15, 2005 | 06:06 PM
RalliArtEvoVIII's Avatar
i have redline driveline fluids. Dont plan to use it again. Thats my .02
Old Feb 15, 2005 | 06:14 PM
hutch959's Avatar
yea, i think the redline stuff is really good if you plan on changing it very often.... like in a race enviroment. Its made to make power and reduce friction, but i think i breaks down a little quicker than other oils. So it really depends what you want
Old Feb 15, 2005 | 06:27 PM
PVD04's Avatar
It's my understanding that Mobil 1 is also one of the few truly synthetic oils. The ones that aren't are usually labeled as synthetic blends.
Old Mar 29, 2011 | 09:29 PM
boczo777's Avatar
me and my friend drove few rallies in his 04 wrx, he was using few different kinds of oils, including mobil1, redline was the ONLY one that oil pressure on idle before and right after stage was same, mobil was cooking almost, 9psi idle, when car cooled down lil bit, 13....redline, NEVER below 20 and i think that is the most important in engine oil, im putting 10w40 redline to my evo and k&n filter
safat_evo
16
Jan 4, 2016 12:02 PM
Silver-IXse
Jan 3, 2014 10:25 PM
evox7
49
Jul 13, 2008 10:50 PM
evovin
22
Aug 7, 2007 06:57 AM
Derek888
16
Nov 14, 2005 07:39 PM
