All Part Number Request Go Here
Old Nov 10, 2004 | 11:18 AM
  #181
lacartus's Avatar
Thanks Joe just downloaded that to my Palm/phone.
Originally Posted by sillypuddy
i was bored.. so here's all the part numbers so far:
MN153284 MR bypass valves
1545A001 MR BOV
Anyone know what is different between these two parts? From searches, it appears the latter is the metal MR BOV...assuming bypass valve isn't another term for wastegate valve.
Old Nov 10, 2004 | 11:27 AM
  #182
sillypuddy's Avatar
I was on the mitsubishi site and they list a "front strut bar" as an option, anybody know if this is a better (stiffer?) version of the one that comes stock? what is the part #?
-joe
Old Nov 13, 2004 | 03:26 PM
  #183
PiNG's Avatar
Angry
Hey, guys, I'm wondering if anyone got part number for:
'05 EVO MR Silver
Right (Passenger Side) Front Fender
Right (Passenger Side) Complete Entire Light (Including Housing, HID)
Right (Passenger Side) Front Wheel well Plastic Dirt covering
Hood
Long story short, something fell out of a truck, and hit my right side, on 91FWY. I pulled over, but the truck left.
Old Nov 14, 2004 | 05:01 AM
  #184
JustDSM's Avatar
'05 EVO MR Silver
Right (Passenger Side) Front Fender MR954150
Right (Passenger Side) Complete Entire Light (Including Housing, HID) MN161172 (this is the entire assy.)
Right (Passenger Side) Front Wheel well Plastic Dirt covering MR954176
Hood MN161277
All parts are listed in bold above. I'm sorry to hear of your accident. Good luck getting the repairs taken care of.
Old Nov 14, 2004 | 04:31 PM
  #185
PiNG's Avatar
Thank You! You've been a great help!
Old Nov 15, 2004 | 01:55 PM
  #186
sgplancer's Avatar
I am looking for a part number, if it even exists, for a pig tail connection for the rear O2 sensor. I am looking for the O2 sensor side so I can completely disconnect the O2 sensor and plug in the pig tail, which will be wired to the O2 eliminator. If this exists, please let me know what the part number is. Thanks.
Old Nov 15, 2004 | 05:57 PM
  #187
sillypuddy's Avatar
I didn't get any bolts with my RS trunk bar, can somebody get the part # for the bolts needed to mount it?
also I just broke 3 out of 4 of those little fastener things that hold the plastic trunk trim (the one with the latch in the middle), can somebody get the part # for them too?
thanks a lot
-joe
Old Nov 16, 2004 | 08:17 AM
  #188
JustDSM's Avatar
Cannot get the pigtail alone. You'll have to buy the whole floor harness. MN124356
Old Nov 16, 2004 | 08:25 AM
  #189
JustDSM's Avatar
thanks a lot
-joe
Bolts: MS240129
Clips: MR572500
Old Nov 16, 2004 | 08:32 AM
  #190
sillypuddy's Avatar
thanks
Old Nov 16, 2004 | 09:41 AM
  #191
djtmotorsports's Avatar
thanks a lot
-joe
They are 8m-1.25 bolts about an inch or so long. I just grabbed some out of my misc. bolt bin.
I use socket head bolts on the trunk bar that I make.
Old Nov 16, 2004 | 10:48 AM
  #192
sgplancer's Avatar
Thanks for finding the floor harness part #, but I may be a bit confused, or maybe you are.
I am looking for the pig tail that plugs into the harness. It would actually be the O2 sensor side of the harness. If I have to buy a whole new rear O2 sensor just to get the connection, then that would be what I am looking for. Thanks in advance.
Old Nov 16, 2004 | 11:44 AM
  #193
JustDSM's Avatar
Ahh, I read you're post a little too quickly. The pigtails for that are also not avail. from Mitsu (I'm attempting to locate the OEM supplier/part # but that'll have to wait until I'm back home)
In any case, as posted above the rear O2 sensor PN# MR578532
Old Nov 16, 2004 | 02:11 PM
  #194
sgplancer's Avatar
Thanks for the check. If you do find the pigtail/harness connection, please post it here, or pm me as I plan on making up several O2 elims that will be a direct plug in. I also plan on posting a how to on it referencing the correct part #/location to buy it at.
Old Nov 18, 2004 | 11:16 AM
  #195
marksae's Avatar
CHRA: MD613507
'03-'04 All Trim levels
Compressor Housing: MD613567
Turbine Houshing: MD613521
All '05 Trim levels
Compressor Housing: MD613573
Turbine Housing: MD613524
***Please note that the MR turbine housing uses the same O2 housing as the previous models. You do not need to purchase a "MR" housing.
I just wanted to clarify with you. So the '05 o2 housings are the same as the '03-'04s right?
