All Part Number Request Go Here
Old May 12, 2008 | 12:11 AM
  #2491
jwick76's Avatar
ugh
Dropped the AC button down the center console through my open ashtray hole while installing my new gauges:-/ It's the one on the triple button hvac control panel on the 2003 lancer OZ... defrost - ac - recycle
I need the number for the ac button. Can't figure out what it's called to search for it. Tried knob/switch/control/etc.
thanks!
Old May 12, 2008 | 05:26 AM
  #2492
MadCrix's Avatar
why not jsut remove the console and retrieve your lost button???
the console is very simple to remove
Old May 12, 2008 | 06:13 AM
  #2493
RussellM's Avatar
Plat Vendor
Originally Posted by kreo
im looking for battery cover or battery Cap
thanks
Do you have an VIII or IX?
Old May 12, 2008 | 10:02 AM
  #2494
jwick76's Avatar
I was debating it, but it fell inside the carpet and sounds like it fell deep, like through a hole in the shifter assembly. I almost had it, it was right on the edge of the carpet hole cutout, and then all I did was make it fall deeper. I don't want to take out the assembly just to find I won't be able to get to it without a crapload of effort. I'm assuming it's just a few $$...
Old May 12, 2008 | 10:54 AM
  #2495
MadCrix's Avatar
lol try man try lol wheres the fun in that?
lol but the shifter is a sealed unit so it would not fall through.. my advice is go at it from an angle and use your wife/girl hand.. smalled hands reach deeper and don't create more space for it to go further lol
Old May 12, 2008 | 12:25 PM
  #2496
jwick76's Avatar
No small girl hands available, my girlfriend has man hands. she's a butcher:-p
heh, any idea what the button is called? It's not called a button, knob, or switch...and I've gone through CAPS a few times trying to figure out what to search for...
Old May 12, 2008 | 01:38 PM
  #2497
chris_k's Avatar
Hi guys greetings from Sweden
I need a part nr for the ac condenser for my Evo 8 -03 (us-spec).
I have found alot of differant number but i dont know wich it is?
Sorry for my bad english.
/chris
Old May 13, 2008 | 08:23 PM
  #2498
hyp36rmax's Avatar
whats the part number for the front core support frame? yes i mean the whole front portion thats welded onto the main support that attaches to the headlights, fmic, front bumper support.
and price if anyone has an idea.
thanks!
borrowed this pix from here:
https://www.evolutionm.net/forums/sh...hlight=fenders
the front frame is what im looking for
Old May 14, 2008 | 11:18 AM
  #2499
RussellM's Avatar
Plat Vendor
thanks!
Here is a link -- its in stock
http://www.mitsubishiparts.net/cart/?id=571&pn=5215A103
Old May 14, 2008 | 11:19 AM
  #2500
RussellM's Avatar
Plat Vendor
/chris
LINK
http://www.mitsubishiparts.net/cart/?id=571&pn=7812a049
Old May 14, 2008 | 11:24 AM
  #2501
RussellM's Avatar
Plat Vendor
This should be it right here. You dont have to use the "search" feature in CAPS...you can actually look up the part.
http://www.mitsubishiparts.net/cart/?id=571&pn=MR500925
Old May 15, 2008 | 06:46 PM
  #2502
BGR's Avatar
BGR
Question MR Oil Drain Plug Part Number?
Hi Guys, as most of you know the MR has an oil drain plug with a sensor and attached wire that measures the oil temp. My oil temp gauge is going crazy back and fourth and I wanted to change the plug to see if the sensor is gone bad. I went to the dealer and they have never heard of a oil drain bolt with a plug. I looked along with the part guy at all the diagrams and all the dealer has is regular bolt. The guy even looked it up with my VIN number. So the question is, does someone know the part number for the MR oil pan drain plug? Is this something that the dealer puts as an aftermarket item? Thanks for your help!
Old May 15, 2008 | 07:08 PM
  #2503
cfdfireman1's Avatar
Drain plug that measures oil pressure? How does that work?
Originally Posted by BGR
Hi Guys, as most of you know the MR has an oil drain plug with a sensor and attached wire that measures the oil pressure. My oil pressure gauge is going crazy back and fourth and I wanted to change the plug to see if the sensor is gone bad. I went to the dealer and they have never heard of a oil drain bolt with a plug. I looked along with the part guy at all the diagrams and all the dealer has is regular bolt. The guy even looked it up with my VIN number. So the question is, does someone know the part number for the MR oil pan drain plug? Is this something that the dealer puts as an aftermarket item? Thanks for your help!
Old May 15, 2008 | 07:30 PM
  #2504
biggie5252's Avatar
It's oil temp, not pressure. I've heard that you can't get it by itself, you have to order the whole gauge set to get it. You might try ebay.
Old May 15, 2008 | 07:32 PM
  #2505
Sounds like that won't fix his problem then.
