All Part Number Request Go Here
Old Apr 8, 2009 | 01:43 PM
  #3046
Dragracer187's Avatar
I am looking for the partnumbers of the injectorclips, fuel pressure solenoid clip and map sensor clip.
Old Apr 8, 2009 | 03:42 PM
  #3047
xxD3MONxx's Avatar
all the bolts to the driver and passengers seats
Old Apr 12, 2009 | 03:03 AM
  #3048
evo_q8's Avatar
fuel pressure regulator for Evo 8
Thanks!
Old Apr 12, 2009 | 10:46 PM
  #3049
PeteyTurbo's Avatar
I need p/n for the following.. for an 05 5 speed
Harness for speedo and reverse switch in the engine bay
washers and pins (clips) for shifter cable/transmission side ( to keep the cables connected to shift linkage)
Washers and retaining pins for shift cables to shifter assy inside the cabin..
Hard clutch line
Old Apr 21, 2009 | 05:29 PM
  #3050
I4UnderPressure's Avatar
Need P/N for Lower injector seals for IX
Old Apr 23, 2009 | 07:56 PM
  #3051
soldave's Avatar
Here's one for you. There are 3 different part numbers for Evo 8 and 9 pistons. What's the difference between A, B and C?
Old Apr 25, 2009 | 12:58 PM
  #3052
prodigalsunn's Avatar
i'm bringing my exhaust back to stock(exhaust manifold back) and as far as gaskets go which ones should i replace? These are the part #'s for what i think i need so far.
MR450703 - DONUT GASKET FOR DOWNPIPE/02 HOUSING EXHAUST DONUT
MR292686 - METAL GASKET TO TURBINE(I believe i have this one, came with stock used ex-mani i got)
MR323654 - EXHAUST MANIFOLD GASKET(HEAD TO EX-MANI)
Am I missing any??? should there be any for DP to cat/testpipe and cat/test to midpipe?
thanks
jake
Old Apr 25, 2009 | 05:16 PM
  #3053
RussellM's Avatar
Plat Vendor
thanks
jake
PM Sent -- Im sending you some illustrations for reference and they are big -- I dont want to post them here.
Old Apr 27, 2009 | 02:49 PM
  #3054
Koroshiya's Avatar
What is this part called and where does it go?
Old Apr 27, 2009 | 06:02 PM
  #3055
Shenanigan13's Avatar
is there a p/n# for ralliart exhaust for 08 evo X MR... and is it possible to put this exhaust on the X. thanks for the help
Old Apr 28, 2009 | 07:14 AM
  #3056
detroit pistins's Avatar
Hi,
Does anyone know what the part # is for the rear O2 sensor that gets put on the cat on the ix models? and how much they are?
Thanks
Old Apr 28, 2009 | 10:39 PM
  #3057
eccccc's Avatar
it's the part that connect to the fender liner
Old Apr 30, 2009 | 03:44 PM
  #3058
SRTRaceR04's Avatar
Edit: Found the info I needed!!
Old May 3, 2009 | 04:19 PM
  #3059
AIEvo9MR's Avatar
What is the part number for the Magnetic Swith on the starter. Thanks
Old May 5, 2009 | 01:34 PM
  #3060
~BoOsTeR~'s Avatar
1005a700 Evo 9 Head Gasket
