All Part Number Request Go Here
Old Aug 27, 2012 | 05:25 AM
  #3796
jrank3792's Avatar
Can anyone tell me the part number for the Drivers side output shaft? The one that comes out of the transfer case.
For an 03 Evo VIII
Also do you know if it comes with the circlips attached to it already?
Old Aug 30, 2012 | 04:51 PM
  #3797
sith_one's Avatar
What would the part number for ignition switch assembly w/key be...Thanks for help in advance
Old Sep 3, 2012 | 06:32 PM
  #3798
yenny's Avatar
Originally Posted by yenny
anyone know where I can get the boot circled in red here or the part # for it
https://www.evolutionm.net/forums/ev...ntrol-arm.html
I ended up finding it. Part # is MR455070
Old Sep 5, 2012 | 06:32 AM
  #3799
Evo_AK's Avatar
Veteran: Air Force
Looking for the part number to an Evo IX RS engine harness.
Old Sep 7, 2012 | 04:29 AM
  #3800
Evo_AK's Avatar
Veteran: Air Force
Anyone?
Old Sep 7, 2012 | 06:20 PM
  #3801
StreakGSX's Avatar
MD569372 air intake rivet .....is this the correct part # for the two plastic clip/screw things that hold the air duct/snorkel in the car? I removed that a long time ago and now want to build an intake sheild and incorporate that back into it but can't find those.
Thanks !!
Old Sep 16, 2012 | 07:15 PM
  #3802
jrank3792's Avatar
Looking for the bolt and nut for the part of the hub where the lower ball joint on the control arm, attaches to the knuckle.
Thanks
Old Sep 22, 2012 | 10:02 AM
  #3803
Anonymouse's Avatar
I searched and didn't find this part so I'll add it here since I just got it from the dealer.
MR970563 - spring clip from the gas door
Old Sep 27, 2012 | 09:09 AM
  #3804
Dirty25RS's Avatar
Evo 8 rear alignment bolts.
Anyone know the PN?
Old Sep 27, 2012 | 12:08 PM
  #3805
apiazza2010's Avatar
I'm looking for the Oil Cylinder Block Plug, the one you remove when doing the timing belt. Anyone knows the part number?
Thank you
Old Oct 7, 2012 | 09:04 AM
  #3806
Evo_AK's Avatar
Veteran: Air Force
Anyone have the part number for the pocket thats under the radio and hvac?
Old Oct 8, 2012 | 10:46 AM
  #3807
TJPhillips36's Avatar
Looking for the number for 1 of the nuts that hold the front suspension crossmember to the frame. Has 2 bolts that go through the lower control arm, and then 2 nuts that hold it up.
Old Oct 10, 2012 | 03:28 PM
  #3808
RussellM's Avatar
Plat Vendor
Please Follow The Link Below
http://www.mitsubishiparts.net/cart/?id=571&pn=MR626784
Im not exactly sure what you are looking for here - email me the request and Ill shoot you over some diagrams and we can sort it. russellm@brucetitus.com
Old Oct 10, 2012 | 04:23 PM
  #3809
Jinxed's Avatar
this list was very helpful in finding what I needed fast
Old Oct 15, 2012 | 08:47 AM
  #3810
05-EVO-GSR's Avatar
Evo steering wheel plastic ring that goes around the airbag?
