All Part Number Request Go Here
Old Oct 15, 2012 | 05:28 PM
  #3811
kaj's Avatar
kaj
not sure if anyone has asked (search came back empty) but need part numbers for the oil seals on the sides of the rear diff. part number 5 here:
Old Oct 15, 2012 | 07:43 PM
  #3812
Roberto774's Avatar
Anyone have the part number of brembo calipers from evo 9? front and rear! Thx!
Old Oct 15, 2012 | 07:54 PM
  #3813
Raptord's Avatar
part number MD707184
(highlighted in red)
Part numbers for Evo IX brake calipers:
Front right: 4605A436
Front Left: 4605A435
Rear Right: 4605A437
Rear Left: 4605A438
All Part Number Request Go Here-mkwf5.jpgAll Part Number Request Go Here-zm8xj.jpg
Old Oct 19, 2012 | 08:42 PM
  #3814
TweAk_VI's Avatar
Hey, I'm after the P/N for Evo 6 engine Trans mount can't seem to source a new one, also Is there another mount thats not from CP9A that is also a correct fit?
Old Oct 20, 2012 | 01:08 AM
  #3815
kaj's Avatar
kaj
you rock. thank you.
Old Nov 1, 2012 | 05:24 PM
  #3816
evo_skillz's Avatar
need evo 9 oem wiper blades, need to replace all of them, both front and back.
Thank you in advance
Old Nov 1, 2012 | 06:26 PM
  #3817
kaj's Avatar
kaj
for real?
Old Nov 1, 2012 | 06:54 PM
  #3818
Raptord's Avatar
Don't know why you wouldn't just get some from autozone or whatever, but here you go. use the "PNC" number to match on the illustrations for what you want (just the blade itself or the wiper "assembly". The part spec appears to be the length in mm of the blade.
Old Nov 1, 2012 | 08:32 PM
  #3819
evo_skillz's Avatar
Thank you
Old Nov 1, 2012 | 08:49 PM
  #3820
evo_skillz's Avatar
excuse my ignorance but I'm not sure what to get, do I need everything highlighted or can I just get the blades for the front and back? sorry I should've been a little more clear.
Thanks again
Old Nov 1, 2012 | 09:15 PM
  #3821
StreakGSX's Avatar
Originally Posted by StreakGSX
MD569372 air intake rivet .....is this the correct part # for the two plastic clip/screw things that hold the air duct/snorkel in the car? I removed that a long time ago and now want to build an intake sheild and incorporate that back into it but can't find those.
Thanks !!
Anyone please
Old Nov 2, 2012 | 05:35 AM
  #3822
Raptord's Avatar
Thanks again
I don't have OEM wipers to check so I don't know if the blade can be replaced seperately from the "bracket" holding it. Since they're 2 seperate parts I would imagine so, in which case you should be able to just get MR300304, MR574655 and MR538219
Old Nov 2, 2012 | 08:18 AM
  #3823
evo_skillz's Avatar
thanks again
Old Nov 2, 2012 | 09:54 AM
  #3824
ProPilot04's Avatar
Guys... does anyone have part numbers for the REAL JDM Evo IX MR tails?
Lancershop is listing this number... MR8330-A001 + MR8330-A002, but when I spoke with Mitsubishi (in Japan) they said the number had changed to: M8330A120 and 119?
I just want to make sure I'm not losing anything in translation?
Old Nov 2, 2012 | 10:14 AM
  #3825
Raptord's Avatar
Anyone please
Not sure exactly what you're looking for, what number is it on this diagram?
