All Part Number Request Go Here
Old Sep 10, 2015 | 08:06 AM
  #4231
vbturbo2's Avatar
The screws are not listed in the catalog. Is there another screw that is in another part that is the same type I can look up?
Old Sep 13, 2015 | 02:02 PM
  #4232
Thoe99's Avatar
throttle cable brackets
I need to replace these two brackets that hold the throttle cable to the valve cover. Can someone help me find the part#'s to them?
Old Sep 15, 2015 | 09:12 AM
  #4233
vbturbo2's Avatar
Throttle cable parts are MN100121 and MN359033
I can do them for 12.50 shipped
Albert
Daytona Mitsubishi
Old Sep 18, 2015 | 05:50 PM
  #4234
mikesevo8's Avatar
Originally Posted by llDemonll
Anyone know the part number for the lower bolts on the front shocks? Not the adjustable camber bolt, just the plain 19mm bolt and nut that go with it
#3 in this image:
Anyone have the PN of the top eccentric bolt ??
I'm sure the nut is probably the same
Old Sep 19, 2015 | 10:38 AM
  #4235
deylag's Avatar
Front Suspension Upper Camber Bolt - MU000284
Front Suspension Lower Bolt - MU140067
Front Suspension Nut - MU000567
or
Front Suspension Nut - MD090875
(more expensive)
Old Sep 19, 2015 | 11:33 AM
  #4236
mikesevo8's Avatar
or
(more expensive)
Thanks.
My bad, I should have been more specific. When I check at Mitsubishiparts.net, those numbers seem to come up for a Evo X.
I have a 2003 Evo VIII
Old Sep 20, 2015 | 12:59 PM
  #4237
deylag's Avatar
Originally Posted by mikesevo8
Thanks.
Yea its the same part number for both Evos. I have ordered these before for my evo as well.
Old Oct 5, 2015 | 09:57 AM
  #4238
Rookie05r1's Avatar
anyone know the part number for the ACD hardline that runs around the bottom of the engine bay and the reservoir? i cant find a parts diagram for the acd system
Old Oct 5, 2015 | 11:23 AM
  #4239
Kevin.'s Avatar
03 evo8 thermostat part number
Old Oct 6, 2015 | 09:17 AM
  #4240
kaj's Avatar
kaj
is anyone still providing part numbers?
if so, i need the number for the gasket/washers for the bypass on the oil filter housing. i guess it would be best to replace both washers since i had them off.
i can't find them anywhere.
Old Oct 6, 2015 | 07:08 PM
  #4241
Thore's Avatar
MN143463
Old Oct 9, 2015 | 10:56 AM
  #4242
vbturbo2's Avatar
MN143643
22.00 Plus shipping, in stock
Old Oct 9, 2015 | 10:59 AM
  #4243
vbturbo2's Avatar
Thanks.
I can get you the MU000284 for 8.00 each plus shipping if you need them.
thanks
albert
Old Oct 16, 2015 | 10:25 AM
  #4244
Kevin.'s Avatar
I am looking for the part # for the rear lower control arm eccentric toe adjustment bolts and nuts for an Evo 8.
I believe the part numbers are: MR171026
MR856459
Old Oct 16, 2015 | 05:07 PM
  #4245
Ricoswave's Avatar
Need the part number for the metal cup that slips over the inboard side of the drivers side front driveshaft ( interfaces with the seal at the transmission). Just bought a used axle and its bent up pretty good, no way it will hold fluid. Hoping its actually available, it did slide right off.
