All Part Number Request Go Here
Old Jun 22, 2006 | 04:45 AM
  #1111
SuperHatch's Avatar
Originally Posted by evo_007
Thanks for those numbers. I got "rear bumper side plate" straight from the service manual, but it bolts or rivets on directly on to both sides of the "rear bumper support" MN175827. It's long and thin and goes with the contour of the bumper's sides, left and right.
R - MR574336
L - MR574335
Old Jun 22, 2006 | 04:47 AM
  #1112
SuperHatch's Avatar
Originally Posted by ez76
Looking for the part numbers to the stock rubber shift linkage bushings (there are two different ones).
The bushings are not available separate from the cables....
Cable P/N - MN107670
Old Jun 22, 2006 | 01:40 PM
  #1113
civilrage's Avatar
hey guys i bought an evo8 steering wheel and it was missing the snap on piece that goes on the bottom to cover the wires etc. anyone got a part number for that peice of plastice?
Old Jun 23, 2006 | 05:44 AM
  #1114
FJF's Avatar
FJF
I wonder if someone could help me with the part number for the brackets that attach to the head unit (radio) and allow it to be flush mounted. Here's a pic from another thread:
Old Jun 23, 2006 | 06:52 AM
  #1115
Grey Razor's Avatar
2005 EVO MR Dashboard Top
Does anybody know the part number for the dashboard itself? I need a replacement dashboard for my 05 MR. Thanks in advance!
- Jason
Old Jun 24, 2006 | 01:37 PM
  #1116
Amazin' Wasian's Avatar
i need the part # for the oil return line gasket....that goes between the line and the pan...
thanks..
-nick
Old Jun 25, 2006 | 06:26 AM
  #1117
SuperHatch's Avatar
MR569203XA
Old Jun 25, 2006 | 06:27 AM
  #1118
SuperHatch's Avatar
MR330703 (qty 2)
Old Jun 25, 2006 | 06:28 AM
  #1119
SuperHatch's Avatar
- Jason
MR633549 - Dash top
MR633550 - Dash Front/bottom
Old Jun 25, 2006 | 06:29 AM
  #1120
SuperHatch's Avatar
thanks..
-nick
MN156738
Old Jun 25, 2006 | 03:20 PM
  #1121
webguy330i's Avatar
Can someone please confirm that these are all the correct part numbers for the 2003 Evo? I've seen references to galant parts from 1991 so I'm assuming that's the 4g63 match up but I jsut want to be sure before I order all of them. This is for my 60k service:
Part # Description
MD979313 Water Pump Kit
MD369999 Pulley+timing Bel
MD326059 Belt+valve Timing
MR984778 Belt+balancer Timing
MN158794 Belt+alternator
water pump, balancer belt, timing belt, serpentine belt, pulley... anything else?
Old Jun 25, 2006 | 08:04 PM
  #1122
SuperHatch's Avatar
Part # Description
The part numbers you have are correct, you might also consider the following...
MD352473 - Balancer Pulley
MR984375 - Timing belt tensioner
Old Jun 26, 2006 | 06:40 AM
  #1123
FJF's Avatar
FJF
Originally Posted by SuperHatch
MR330703 (qty 2)
Thank you.
Old Jun 26, 2006 | 02:58 PM
  #1124
webguy330i's Avatar
Hey thanks man, good advice.
What is the MD369999 part for exactly? I'm a little unfamiliar with all these parts to be honest. I thought this was the balancer pulley but apparently not?
Also is the timing belt tensioner a tool, or a part that needs to be replaced?
I suppose a breakdown of these parts would explain it all, if you have a spare minute.
MD369999 vs MD352473 vs MR984375
Old Jun 26, 2006 | 06:23 PM
  #1125
SuperHatch's Avatar
MD369999 is the tensioner pulley for the timing belt. The tensioner (MR984375) pushes on an arm that the MD369999 pulley is attached to, those two parts together keep tension on the belt. It also self adjusts over time to keep consistent tension.
MD352473 is the balancer belt pulley, it keeps tension on the balance belt. The tension on the balance belt is set at installation and does not self adjust.
