ECU reset
Old Mar 12, 2003 | 09:46 PM
limey's Avatar
ECU reset
Everyone is experiencing after thier break in period a lack of power higher up the revs.....for those of you that have broken your cars in...try disconnecting your battery for about 30 minutes...in england this used to work on subaru 4 cam turbos it made a huge difference...if you are running decent gas now and not driving like miss daisy because of the break in period ...you need the ecu to find a different map...I have heard this can only be accomplished by disconnecting the battery...this may not work now because of newer technology...but hey it's worth a try...after re-connecting the battery take the car for a fast drive and see what happens
Old Mar 12, 2003 | 09:59 PM
MalibuJack's Avatar
I'm fairly certain that disconnecting the battery and letting the car sit for 20 or so minutes should be long enough to cause the ECU to "reset" I do know there is a function within the OBD-II Diagnostics that will force it to re-learn also.. But I don't have my car yet to try it. I have done it with my Fuel Injected Neon.. But it is just a girly neon..
Old Mar 12, 2003 | 11:09 PM
rooster's Avatar
That may work.
Old Mar 13, 2003 | 01:14 AM
Yojimbo's Avatar
I want to hear what happens when/if someone wants to try. Let's hope this thread stays alive.
This thread would probably be best in Tech though I would think.
Old Mar 13, 2003 | 01:22 AM
Dem1K's Avatar
ok everybody...look; theres been 2 threads on this, and on one of them, they said to D/C the NEG. terminal ONLY!!......on the other one, it says to D/C the POS. terminal....which do i D/C? Plus, if i D/C the POS. terminal......how? What do i take off? can some1 PLEASE take a few pics of what exactly to take off cuz i dont kno WHAT the hell i'm doing....any help is appreciateD!!
Old Mar 13, 2003 | 01:37 AM
ghostrider's Avatar
Disconnecting is disconnecting; it doesn't matter if you do the positive or the negative. It's just that you can get zapped if you use the positive terminal.
Old Mar 13, 2003 | 01:46 AM
Dem1K's Avatar
well that about fuc**n clears that up now dont it?
Old Mar 13, 2003 | 02:09 AM
BlackLancer2k2's Avatar
guess so..
Old Mar 13, 2003 | 02:40 AM
ghostrider's Avatar
Forget the positive terminal then, and just stick with the negative terminal. There's one bolt to loosen. Pretty ****ing clear, huh?
Old Mar 13, 2003 | 03:01 AM
Dem1K's Avatar
well **** then, you couldnt have said it better yourself
Old Mar 13, 2003 | 09:39 AM
Jonasan50's Avatar
Disconnect them both, it don't freaking matter...
Old Mar 13, 2003 | 09:54 AM
nomoore's Avatar
Always disconnect the negative cable first and hook it up last. It is less likely to spark. If it sparks and there are fumes from the battery there the battery could explode. Exploded batteries are not pretty. I've seen them dent hoods quite badly. You don't want that.
Old Mar 13, 2003 | 11:52 PM
Yojimbo's Avatar
Now that we've put our collective head together and figured out that disconnecting = disconnecting.. .. someone tell us if this makes any difference whatsoever after a little bit of driving.
Anubis7
Mar 30, 2017 09:00 PM
ChristianB
Dec 4, 2016 08:19 AM
Royal Evo
Mar 17, 2016 11:57 AM
Dynafit
Oct 16, 2015 01:46 PM
ShtrMcGavin
Jul 26, 2006 08:35 PM
