good replacement battery (not mini!) for evo.. suggestions?
Old Oct 13, 2005 | 01:56 PM
J8dailo's Avatar
get the optima yellow top...best battery for the money
Old Oct 13, 2005 | 02:08 PM
@llEyezOnMeeH!'s Avatar
I have a Lightning Audio battery that powers my JL 1000/1, 450/4 and 2 12" Eclipse Titanium subs. Just as good as the Optima without the yellow or red tops. Mainly black although it does have some purple. Works great for me though.
REVO's Avatar
With your system, and not really using the woofer(s) often, you should've been fine with the OEM battery... Now, if the batt went dead after a few days in the garage, there's something (within the sound system or another electrical accessory) that's consuming a considerable amount of power even while the car's off. You may want to check that first with an amp-meter. There's also the chance your OEM battery had a defect, and there isn't a real problem with your electrical system...
Just my $.02
Good luck!
Old Oct 13, 2005 | 02:17 PM
Evo#1's Avatar
Just my $.02
Good luck!
I agree, I would also check to see if every thing is grounded properly and check the 12v remote lead wire going to the amps
Old Oct 13, 2005 | 02:51 PM
PurgeIt's Avatar
My homies over at Audio Options (who build some of the finest audio systems in the country) recommend dry cell batteries like Odyssey. I had that in one of the systems they built for me - running 2 sets of components for front stage - one set in stock location, one set in footwell - rear fill, 3 amps, two 10" subs... never had a single problem. Never had a problem with a dead battery either.
Old Oct 13, 2005 | 06:47 PM
TurboSaleen#163's Avatar
Originally Posted by Anarchy99
Optima, Yellow or Red top.
Agree
Old Oct 13, 2005 | 08:10 PM
cky3396's Avatar
thanks guys, it was in fact a dud battery. ive had my system for over a year and have left my car while on vacation afew times with no problem... bad battery, gotta new one... all is well
thanks again
Old Oct 15, 2005 | 08:24 PM
sail0rm00n's Avatar
I did a lot of research in looking for a new battery too and Optima yellow tops came up a lot
Old Oct 15, 2005 | 10:32 PM
whiteEv0boy's Avatar
What about the Exide Orbitals? Are they any good? I had an Optima Yellow top in my integra and it died around winter (less than a year)
svt_lightning01
Mar 10, 2012 02:16 PM
onewickedninelv
Apr 29, 2010 11:20 AM
TangoASI
European Forum
10
Nov 12, 2008 09:33 AM
Bexa20
Mar 7, 2007 05:15 PM
mattjkim
Jan 1, 2007 10:13 PM
