how to clean intercooler?
Old Oct 22, 2005 | 09:33 PM
tequila083's Avatar
How can i clean my intercooler the exterior part and the interior.?
Old Oct 22, 2005 | 09:38 PM
MrMejia's Avatar
take it apart and do not blast with water because the core will rust, instead use compressed air or some stuff that does not rust (ex: brake cleaner) be creative. as for the inside I would dampen a lint free rag and put in on the end of a rubber tube and push it in and out of the end tanks if your hands are too big like mine. be creative.
Old Oct 22, 2005 | 09:58 PM
dsm95hybrid's Avatar
Pressure washer... gasoline on the inside will remove the oil.
Water will not rust the FMIC . That was an untrue statement.
Missred's Avatar
Ive always cleaned mine with simple green, let sit for a few minutes then hose down the exterior. Never had it rust before and Ive cleaned it this way on my 1st gen eclipse when it had stock side mount and now its front mount in the last 8 years. If you really want to get down and dirty remove bumper and do a wipe down.
Old Oct 22, 2005 | 09:59 PM
Missred's Avatar
Water will not rust the FMIC . That was an untrue statement.[/QUOTE]
I agree
Old Oct 22, 2005 | 10:03 PM
BuLocal's Avatar
If your not going to takke it off the car: I use a stiff "art type" paint brush to poke through the grill and get the bugs off every once and a while. Just kind of brush them off and a little squirt of water and your good to go. For the inside, dont know.
Old Apr 15, 2020 | 04:45 PM
Ryan Clarke's Avatar
Intercoolee cleaning
Correct me if I'm wrong but as the intercooler is made of aluminum it will not rust .
I was thinking internally to:
- run hot water with CT-18 truck wash through the same direction as it normally flows.
-rinse with cold water after
-Then run cleaning alcohol through after it sets to get any additional grease that the hot soapy water did not get ?
Assuming that internally the biggest pollutants will be from normal blow by ?
Let me know if this sounds like a good idea because I'm about to start cleaning up my Evo 5
Thanks guys
Old Apr 15, 2020 | 05:06 PM
LetsGetThisDone's Avatar
Thanks guys
This is a 14.5yr old thread.
Old Apr 15, 2020 | 05:26 PM
osetsky's Avatar
Lol, so does that give this some kinda necro bump record?
Old Apr 15, 2020 | 05:28 PM
I been up all night researching Evo 5 mods ....I geuss I could start with a Thankyou 💪💪💪😎😎😎...cheers to all the input fellas
Methodical4u
Aug 25, 2010 08:54 PM
B350
Jan 31, 2009 07:11 AM
Noe18
13
Mar 9, 2008 10:45 PM
sokaroza
17
Nov 21, 2007 12:05 PM
neyugn_naut
Apr 12, 2005 05:54 AM
