Project EVO 9 begins..
Old Jan 2, 2006 | 03:09 AM
  #181
autoplus's Avatar
Ed,
Is the downpipe and exhaust system you are using 75mm, 80mm or 95mm? thanks!
Randolph @ Autoplus
Old Jan 2, 2006 | 04:00 AM
  #182
autoplus's Avatar
Originally Posted by hanahawaiian
Im thinkin between 2.2 or 2.4 Stoker Kit.. I like JUN and TODA racing stoker kit.. JUN had 2.2 only.. TODA i dont know.. but AMS had 2.4... I want going to JDM parts
bro,
Our JUN equiped 2.2L stroked Evos boosting at not even more than 22PSI had created minced meat out of 2.3L and 2.4L stroked Evos here in the Philippines. Our GT-R, only running at 2 bar and a JUN Special RB26DETT race engine and twin HKS3240 made 857AWHP on pump gas!
JUN is damn expensive but after beating all other cars, you will tell yourself you made the right decision =). Not that I am selling JUN products, but based on our experience, they are worth it.
Our usual set-up is JUN + HKS + Garrett + Motec
Old Jan 2, 2006 | 08:26 AM
  #183
hanahawaiian's Avatar
Autoplus... u tell me that JUN stoker kit is good? im little confused
Old Jan 2, 2006 | 12:25 PM
  #184
autoplus's Avatar
Yes to me it is the best made to the highest quality... but its the most expensive too
Old Jan 2, 2006 | 12:28 PM
  #185
Really... how compare AMS Stoker 2.3 It going 9 sec in Quarter... so Jun 2.2 more high compressor or something to bolt on make more faster than AMS? or AMS is faster
Old Jan 2, 2006 | 01:12 PM
  #186
superz's Avatar
I love the pics. But I have a few things that I see that bother me. As an Evo enthusiats and tech since they first arrived I see that all of the parts being installed have been tried long ago. 3 issues with lack of expertise in install also.
1. why would you use the standard hose clamps. IC pipes popping off is just poor attention to install.
2. The twin-power DLi-II is mounted and you used the mounting bolt to also ground it. It clearly states in the instructions to not ground it on the mounting bolt .
3. Running a dump pipe 1/2 away from the undertray is nuts. A good raceday and it will melt or possibly catch fire.
As Warrtalon stated and others, the IX gets its higher stock whp from its turbo, ecu (leaner maps), and its MIVEC. An 8 with a simple reflash will be at the same level. The MIVEC is useless with a bigger turbo swap since the rpm power range is pushed up. Bigger cams like 272's will help in a way that MIVEC cant. Therefore an 8 with cams will undoubtebly make more power than a IX with stock cams. Therefore a IX with a bigger turbo will be limited to the amount if air that the stock cams will let through. The HKS 3037 kit has been around for such a long time that its quite outdated. The AMS gt35r kit will breathe better, make much more power and last much longer.
The project is nice in that it showcases the best HKS can offer, but it will be outrun by any average joe that puts his own Evo together. Im not hating on you guys , just pointing out the obvious. Like I stated before, everthing that you are installing has been tried long time ago and has also been left for better set-ups.
The IX will not majically make more power than an 8 with the same setup, in fact less whp since the cams are still stock. This I will bet my reputation on.
Old Jan 2, 2006 | 02:38 PM
  #187
PurgeIt's Avatar
Originally Posted by Evasive EVO
I think that any kit that converts the way the oem clutch functions is going to have fitment issues.
I guess Helix test pipe cause we didn't want any catalyzer at all? :P
I have some pictures of an HKS Cat thats over at SP right now, they look REAL high quality. I will post up later.
Ed
Well, if you guys can do a test pipe vs. metal catalyzer dyno comparison, that would be most awesome. And yes, I do care about the environment for what it's worth :-P
Old Jan 2, 2006 | 02:39 PM
  #188
PurgeIt's Avatar
Originally Posted by autoplus
Ed,
Randolph @ Autoplus
HKS only makes a 65mm or 70mm... for the Evo that is.
Old Jan 3, 2006 | 03:35 AM
  #189
autoplus's Avatar
The evo 7 of Norris Designs only runs on an HKSGT3540 (equivalent to a GT35R) but using a JUN 2.2 and made it to the 9s. Our Evo 6 TME uses a JUN 2.2L stroker with an HKS T04S at only 2.2 bar but made it at 9.7secs ET.
FYI, the most important thing in a stroker kit is the crank. The AMS crank makes use of a 4G64 crankshaft. JUN manufactures their own and modifies it.
If u want to know more about the JUN stroker kit, read on at www.junauto.co.jp
There was a poll here one time on the best stroker kit and JUN got the most compared to the Tomei, Toda, and AMS. Though it is very expensive, so get ready to dig deep into your pockets.
Old Jan 3, 2006 | 05:09 PM
  #190
DragNRacing's Avatar
This car is also 600 - 700 lbs lighter than a stock EVO.
Old Jan 3, 2006 | 06:02 PM
  #191
thanks autoplus!
Old Jan 3, 2006 | 06:07 PM
  #192
i wounder how much jun stroker kit cost?
Old Jan 3, 2006 | 06:37 PM
  #193
jasonc32amg's Avatar
http://www.upgrademotoring.com/perfo...n/strokkit.htm
$6,500
Old Jan 3, 2006 | 06:44 PM
  #194
M00kiE's Avatar
Where do you get pricing on the JUN parts?
Old Jan 3, 2006 | 10:45 PM
  #195
HOLY CR@P!!!! 6000 grand and over for that JUN!!! geezzzzzz!!!!! then i have sell something to Black market to get JUN lol
