First oil change?
Old Dec 13, 2005 | 10:07 PM
chaotichoax's Avatar
6 months or 3000 miles is pretty standard for your average oil change
in your case I'd change it when you plan to take the car out in the spring...trust me it will be a good idea
fresh clean oil = your friend
Old Dec 14, 2005 | 05:53 AM
CAD EVO's Avatar
Mobil 1 synthetic oil is designed to keep its oil life way past 5000 miles. The first change being the most critical, I disagree, very well built motor, something as minimal as changing it 1000 miles after the guy who changed it at 500 would not make any difference.
Old Dec 14, 2005 | 06:07 AM
bigric09's Avatar
my 03 i changed at 700 and every 3000 after that which is what the mitsu video said the break in was and recommended oil... my ix im waiting for 1000, at 850 as of this morning... then every 2500 to 3000 after that. best oil for cold weather guys ? 5w30 i think ?
Old Dec 14, 2005 | 06:10 AM
bigric09's Avatar
very true, but you have an engine break in and you are going to have burs on your inner engine parts that the factory wouldnt take the time to grind off and that grind off during normal operation and are pretty harmless but dont need to build up in your oil and dont need to be spread around thru your internals. even mitsu recommends the break in oil change. its just like anything high end, a motorcycle is a good example, they have a 700 mile break in as well and have you change the oil... its good practice
Old Dec 14, 2005 | 06:43 AM
walkedu's Avatar
When i got my new warrantied engine, i replaced the oil at 300 miles and then again at 1300 miles for good measure. Can't afford for my Evo to be in the shop for another 8 weeks with a blown rod again
Old Dec 14, 2005 | 10:52 AM
05SilverEvoVIII's Avatar
first:1,500
Second:4,500
4,000 after that
304MR
Nov 8, 2013 09:29 AM
5LEEPERISAH23I
Feb 16, 2011 03:54 PM
qbzescobar
Nov 24, 2010 07:54 AM
RrK
Lancer Troubleshooting
10
Aug 2, 2010 09:16 AM
evox34
Dec 17, 2008 08:37 AM
