PRUVEN PERFORMANCE Evolution IX
Old Dec 19, 2005 | 06:28 AM
Sharkbite2000's Avatar
Yup i think thats what happend. , like i said its my first Evo and he told me the boost wasnt going to change and go up and it wasnt like i was going 160 MPH.
Guess it was my bad luck that i wasn't informed of this situation until it was too late.
But lucky i still have My trusty M3.
Old Dec 19, 2005 | 06:44 AM
yellowEVO21's Avatar
i feel like there's some missing info here...if your dealer swapped out the ECU then I don't really understand how Al or Pruven is responsible here, esp with the minor mods that you're running....well i hope everything works out for you!
forum04pl's Avatar
Originally Posted by ciphermonk
360whp is an awful lot of power out of just an intake and a flash. How much boost were you running? What was your AFR after the tune? Although the dealership swapped the ECU for a stock one and your engine let go a day or so later, it would be safe to assume that the damage was done before the ECU swap. Again, 360whp on just an intake and flash is about 55 - 60whp too much. I'd be interested in what how much boost you were running and what your AFR was. There's no way your engine should have let go at that whp level assuming a good tune. But again, you were about 60whp stronger than you should have been given the mods you stated...
very true, i would also like to see the afr's and the boost levels seeing how al himself set them with the tune. therefore, if it was too much boost or a bad afr it is still not really his fault even though the ecu was changed out.
Old Dec 19, 2005 | 06:57 AM
I'm not saying it his fault but the reason of the change was that the program messed up the ECU beond repair so it had to be swapped out. should of been informed, i mean if im taking my car to your shop and dropping money you should let me know. (he sent me to his guy at the dealer to check my car which they said they couldnt touch it.)
As long as they come through with my car i have no problem i trust they will make good with me im not doubting it.
I should of left it stock if i really knew this was gonna happend so quick.
Old Dec 19, 2005 | 07:04 AM
forum04pl's Avatar
well you seemed to have followed directions of a tuner, if you did what he told you to and nothing more to solve the problem then you should not be at fault
Old Dec 19, 2005 | 07:06 AM
Thank You.
Old Dec 19, 2005 | 07:14 AM
deadbeatrec's Avatar
hummm somthing is missing? r u saying that dynoflash AL tuned your car? or is it a different AL? i have beent o pruven and they know what they are doing. i really cant say much about this one. i also have a full tune dont byb AL at pruven.
slostjoe's Avatar
i still want to know what kind of boost it was running
Old Dec 19, 2005 | 07:18 AM
justchil's Avatar
Originally Posted by Sharkbite2000
that is correct was flashed then it had a problem and ECU had to be replaced then the big problem started !!
You should have put that in your first post.. The bashing will probably start before too long.
That sucks tho.. please let us know exactly what the problem was (when you find out)
Old Dec 19, 2005 | 07:19 AM
jamevo8's Avatar
This is why I am doing an SAFCII on my IX rather than a flash.
Old Dec 19, 2005 | 07:23 AM
Yea Al the same guy from dyno flash, I heard alot of good things about the guys at Pruven i trust my problem will be fixed , if not ill be sure to let you guys know.
Old Dec 19, 2005 | 07:25 AM
EvoJimbo's Avatar
Upgraded Turbo + Untuned ECU @ full boost = recipe for diaster.
Old Dec 19, 2005 | 07:35 AM
QuickSilverDS's Avatar
waits for Al or Dan to chime in with a more "technical elaboration" about the situation.
Old Dec 19, 2005 | 07:43 AM
40psiEVO9's Avatar
So the car wasn't runing, when it was taken to the dealership? How do you know the motor wasn't damaged before?
Old Dec 19, 2005 | 07:50 AM
ciphermonk's Avatar
What octane fuel were you running when you made 360whp?
