PRUVEN PERFORMANCE Evolution IX
Old Dec 19, 2005 | 07:55 AM
  #31
Sharkbite2000's Avatar
93 octane, and the car wasnt running when it got there. I dont know if the damage happend before the ECU went bad.
All i know its Messed up and its sitting at PRUVEN and im gonna rebuilt the entire engine i have no choice at this point.
Old Dec 19, 2005 | 07:58 AM
  #32
ciphermonk's Avatar
Wait.... You're telling me that you had 93 octane in the car when it made 360whp? So it was
Intake
Cat Back exhaust
and rom tune?
Old Dec 19, 2005 | 08:03 AM
  #33
byron3636's Avatar
360 sounds like a ton of whp for that mod list. had to be a ton of boost going on
Old Dec 19, 2005 | 08:11 AM
  #34
Rnm's Avatar
Rnm
Something is fishy...
Old Dec 19, 2005 | 08:13 AM
  #35
AutobonEvo's Avatar
so was the car running like crap on the flash? Then you brought it to the dealer and the dealer said that the ecu was bad and swapped a new ecu in and then your motor blew? im still confused?
Old Dec 19, 2005 | 08:14 AM
  #36
At that time it had no Exhaust just intake, i have the dyno's to prove it also , Al also has the dyno's too so you can verify.
Old Dec 19, 2005 | 08:16 AM
  #37
ciphermonk's Avatar
My thoughts exactly. There's no way that 93 octane is going to support that much whp given the few mods that he has safetly. The boost would have to be turned up past stock for sure.
Old Dec 19, 2005 | 08:20 AM
  #38
byron3636's Avatar
I just know if you look in the dyno slips and look in the 360whp range there's a lot of work done.
  #39
jamevo8's Avatar
I recall Al posting about this tune I remember it being 100 oct?
Old Dec 19, 2005 | 08:21 AM
  #40
QAT-R's Avatar
Indeed. If you only added an exhaust+intake you should have not damaged anything w/ the stock tune, I'm sure the damage was done before you swapped out the ECU.
360WHP = test mule.
I'm really sorry but I sincerly thank you for informing the community and being very understanding about the whole issue.
P.S. I'm sure some groupies will be flaming you soon.
Old Dec 19, 2005 | 08:22 AM
  #41
schumi's Avatar
PRUVEN PERFORMANCE Evolution IX Today, 04:04 AM #1
PRUVEN PERFORMANCE EVOLUTION IX My car is still at PRUVEN PERFORMANCE hopefully it will not blow up this time!! ,, my car blow the engine after some ECUTECK problems and other issues hopefully the guys at PRUVEN PERFORMANCE take care of me. I Never expected a EVOLUTION 9 with intake and cat back exhaust would blow the engine.
Careful on modification to your New EVO IX so you dont wind up like me. once you add intake and software kiss your warrenty GOOD BYE!!!
Dealer will not honer any modifications!!!
YOU BEEN WARNED!!!
I will keep you posted if AL from PRUVEN PERFORMANCE does right by me like he said he would.
First let me say that AL does not work for PRUVEN PERFORMANCE, but works out of their shop. So you might want to take their name off of the title. If that is the case.
second you need to provide more detials.
Old Dec 19, 2005 | 08:27 AM
  #42
EVOKing8's Avatar
this thread sounds a lil wack to me...
Old Dec 19, 2005 | 09:13 AM
  #43
Warrtalon's Avatar
Originally Posted by jamevo8
This is why I am doing an SAFCII on my IX rather than a flash.
What is why? Because one fishy thing happened with a flash that has not been confirmed yet? The SAFC can't properly manipulate the 6 ECU maps on the IX, and flashes have been used for 3 years now without worry. This thread is not a valid reason for saying you choose to use an SAFC.
I don't know how this guy got 360whp on pump gas. Now, he's saying the exhaust wasn't even installed when the dyno was done? The whole thread is very confusing, because all the details are changing with each post. We'll probably need Al's input to get the real story. Hopefully, though, sharkbite will be compensated for the damages if they weren't his fault. He already said that Al is taking care of him, so I'm not exactly sure why he posted the thread. It's best to post it after the fact rather than cause all this speculation based off partial details that currently don't add up.
Old Dec 19, 2005 | 09:14 AM
  #44
ciphermonk's Avatar
Amen and a boomshakalacka...
Old Dec 19, 2005 | 09:28 AM
  #45
YellowFever's Avatar
an SAFCII is more likely to blow up than a Flash. An SAFCII does not control ignition or fuel timing.
