Code: P0234
Old Feb 20, 2006 | 08:20 AM
Viciouslord's Avatar
Code: P0234
well after i installed the Forge Unos MBC, Forge Type RS Valve, and Buschur Deluxe IC.... i'm getting the SES light....
now when i'm at WOT sometimes it will feel like a sudden drop in power (like hitting a wall) but it does not do this all the time....
i go to discount to pull the code and it said it was "P0234: Engine Overboost Condition"... but i look up the code on here and it says "DTC P0234: Turbocharger Wastegate System Malfunction"
any ideas?
thanks,
- Eddy
Old Feb 20, 2006 | 08:30 AM
Nez136's Avatar
The power drop sounds like fuel cut, what are you tuning with? p0234 is a soft code, meaning it wont affect drivability, i threw the code for the longest time until i installed larger injestors. You might want ot try bringing the boost down if you haven't done so yet.
Old Feb 20, 2006 | 08:48 AM
i am not tuning with anything right now... i have an SAFCII from my DSM days but i dont know if i will be installing it....
- Eddy
Old Feb 20, 2006 | 08:49 AM
use2vtec's Avatar
Do you have the new style or the old style Deluxe intercooler? The old ones have slight clearance issues with the wastegate (lower intercooler pipe coming off of turbo going to the intercooler). I bet if you have the old one you bent your wastegate actuator installing it and this is creating a overboost condition. Do you have a boost gauge in the car?
Old Feb 20, 2006 | 08:53 AM
yes i do have a boost gauge.... it shows 20-21 psi at WOT...
i have the new style IC... i did notice the clearance issuse...
- Eddy
Old Feb 20, 2006 | 08:57 AM
evocanival's Avatar
i would definately get the ecu tuned, it could be ur problem, and make a huge difference
Old Feb 20, 2006 | 08:58 AM
use2vtec's Avatar
- Eddy
20-21 psi will not make the car hit fuel cut. If you have the new style intercooler then you should not have any fitment issues at all. Try turning your boost controller down a little and see if you experience this same issue. It could be that you just have a bad boost gauge but I doubt it. Often when people install new intercoolers they see a increase of boost anywhere from 1-3 psi and this could be making you hit fuel cut. Like I said though for that to happen your boost gauge would have to be bad and that is unlikely but ive seen it before. Goodluck
Old Feb 20, 2006 | 09:11 AM
GTSMWET's Avatar
Get a tune, i won't even drive my car until i do, well i will have to drive it to AMS, but thats all, its running really lean right now, i took it around the block thats it, AMS will be putting in new injectors and a Walboro, along with a tune. To make it all run smooth, and try to avoid throwing CEL's
at least get a SAFC
Old Feb 20, 2006 | 09:56 AM
what am i lookin to spend for the flash...
- Eddy
Old Feb 20, 2006 | 09:58 AM
GTSMWET's Avatar
200 for a base flash courtesy of AL
www.dynoflash.com
Old Feb 22, 2006 | 01:17 PM
Jamie@WORKS's Avatar
Check for boost leaks and/or dirty VAF sensor.
Old Feb 22, 2006 | 01:20 PM
forbidden color's Avatar
does your boost gauge lay at 0 when you turn the car off?
Evo2003GSR
Dec 25, 2011 04:56 PM
healthynine
Jun 2, 2011 09:26 AM
ilikeboost
Dec 31, 2010 01:58 PM
rudy91889
Nov 16, 2010 02:40 PM
SlowCar
Aug 14, 2005 05:11 PM
