intake induction
Old Jun 3, 2006 | 03:11 PM
brandy kaiser20's Avatar
ses light just put on intake
i just put on an aftermarket intake and took off the induction piece and am now getting a service engine soon light do i have to have it on or what can i do to get rid of the light
Old Jun 3, 2006 | 03:17 PM
gsrboi80's Avatar
doh
Old Jun 3, 2006 | 03:20 PM
whitersevo's Avatar
why woul u change the stock air box??
Old Jun 3, 2006 | 03:26 PM
should i leave it stock or what i got about a 2psi boost gain from it but that stupid *** light came on again the dealership said it cant run right unless it has those plastic pin in it whats the deal with that
Old Jun 3, 2006 | 03:30 PM
DocMortal's Avatar
You need to get it tuned.. With an intake,but your SES light shouldnt of came on with just that upgrade... cant you pull the code?
Old Jun 3, 2006 | 03:41 PM
havnt tried i am going to get it tuned once i get my cams and cam gears what else should i get i want to get 400wheel power
Old Jun 3, 2006 | 04:21 PM
so does it matter if the plastic induction to the air box is on or what is causing my ses light to come on
Old Jun 3, 2006 | 04:24 PM
Kings Fan's Avatar
Why don't you by a OBD2 scanner and pull the code? Or go to a local auto parts store, they can pull the code for you and you can figure out what's wrong with the car.
Old Jun 3, 2006 | 04:29 PM
DocMortal's Avatar
Pull the code.. go to autozone or autoparts... sometimes you need to reset the car when you do certain upgrades..especially with intakes... You disconnect the battery for like 10min...before you reset the ecu pull the code so you know what it is... When u disconnected the harness to the Maf it might of caused the SES.
Pull the code then you will know whats going on.
Old Jun 3, 2006 | 06:54 PM
whitersevo's Avatar
u should of just left the intake alone, ur not going to gain much from having it on, now ur just costing your self more money.... from what you could of put into your evo....
reboundicon
Dec 17, 2014 12:04 PM
KazzEvo8
May 20, 2009 11:37 AM
MaxKanisha
19
Sep 23, 2008 10:28 AM
IVERSON3270
13
Mar 10, 2007 12:36 PM
Derek888
33
Aug 4, 2005 01:30 PM
