[Nuisance] Gearshift Squeak
Old Sep 11, 2006 | 05:42 PM
PessimiStick's Avatar
I just started getting an annoying "plastic on plastic" squeak from my gearshift when going into second. It's worse if you put pressure to the left as you shift, but there even if you don't. I assume it's just the collar and the cage rubbing against each other, but I was just wondering if anyone else has the same sound, and if there's any way I can grease it without taking out the whole center console. (Lazy ftw).
Old Sep 11, 2006 | 05:45 PM
3SgteGuru's Avatar
try shifter bushings, but check it out first. Thats just my guess.
Old Sep 11, 2006 | 10:13 PM
boostless's Avatar
I have the same thing!!! From 1st to 2nd. Mine goes away when it gets warmed up though. I don't know if I want to take it in or take it apart to lube it. It's probably normal
Old Sep 12, 2006 | 05:37 AM
jd323's Avatar
You'll need to take off your center console and lube the base of the shifter were it makes contact with the plastic housing. The grease has dried up and is causing the annoying rubbing sound. Syl-glide should be okay to use and can be purchased at your local napa auto parts.
Old Sep 12, 2006 | 05:40 AM
PA-silver03evo's Avatar
I used to have it all the time in my 03. Havent heard it in the 06 yet. I guess it will probably start sooner or later. It was kind of annoying but I was always too lazy to mess with it.
Old Sep 12, 2006 | 06:17 AM
That's what I figured. =\
Guess I know what I'm doing tonight!
Old Sep 12, 2006 | 02:04 PM
IXToes's Avatar
I got the same exact thing at around 2.5k miles. It's annoying as hell and my passenger thought there was a crowing rooster once. "Who the hell has a rooster in our neighborhood?". I told him that was my transmission making a rubbing noise.
I guess I'll get some syl-glide. Is that the recommended lube to use?
Old Sep 12, 2006 | 02:23 PM
MREvOTard's Avatar
mine does the same, i was thinking grease the joints with that white grease i forget what its called.
black ralliart
Jan 17, 2017 11:30 AM
Cyrax91
Nov 21, 2016 07:20 AM
Methodical4u
Dec 21, 2010 05:43 PM
Mosaic
Aug 21, 2010 12:34 AM
Ralli04
May 7, 2007 05:29 PM
