Fog lights on with Parking lamps!!!!
Old Nov 14, 2006 | 06:37 PM
Hot Wheelz's Avatar
Does anyone know if it is possible to run the Fog lamps with the Parking lamps only. And How? Wiring suggestions etc...
Old Nov 14, 2006 | 07:23 PM
hondafan's Avatar
bump, subscribed.
Old Nov 14, 2006 | 07:28 PM
EiEVO's Avatar
i dont know but it would be nice to know.
Old Nov 14, 2006 | 07:30 PM
sherif41119's Avatar
Yea, let me know if you find out how.
Old Nov 14, 2006 | 07:34 PM
diablo2184's Avatar
i have been waiting for this for the longest time....no one has done it on a 9...a friend of mine is going to do it soon (i think), so maybe he'll do mine.
if anyone on here knows for sure how to, please explain
Old Nov 14, 2006 | 07:47 PM
Evoryder's Avatar
possible.
Old Nov 14, 2006 | 08:05 PM
boostless's Avatar
i remember reading about someone wit an 8 doing it, but wouldn't tell everyone how. The harnesses can't be that different
Old Nov 14, 2006 | 08:08 PM
diablo2184's Avatar
let me know if u find out for sure how to do it
Old Nov 14, 2006 | 08:39 PM
cableguy5752's Avatar
subscribed
Old Nov 14, 2006 | 10:21 PM
SophieSleeps's Avatar
Find the relay for the fog lights.
Take the spade that is used to power the relay.
Send that to a fuse instead of where it is currently being connected.
The fuse will dictate when the fogs can be turned on or off.
Old Nov 15, 2006 | 04:00 AM
Hot Wheelz's Avatar
Have you done this with your ix?
Old Nov 15, 2006 | 04:07 AM
mrbkkt1's Avatar
negative, it doesn't work. I do know how to make it work though....
You will need a front ecu for a jdm evo. all the lights are ecu controlled from a seperate ecu in the engine bay, under the fuse box. seriously. i've tried everything to try and trick the computer, but will need a detailed wiring diagram to succeed.
Old Nov 15, 2006 | 04:17 AM
Hot Wheelz's Avatar
Thanks for the heads up - Can we buy the jdm ecu from the dealership?
Old Nov 15, 2006 | 04:25 AM
mrbkkt1's Avatar
Not that I know of, I've tried..... You only need the front ecu, i've been trying to find a japan part out, but unfortunately I don't speak( even if i am half japanese...)
Old Nov 15, 2006 | 04:29 AM
3SgteGuru's Avatar
I Beleive the Fog lights, along with Pretty much all the other accessories on your car, are controled by the ETACS ECU. Thats why when you turn the car off your fogs don't have memory and soo next time you turn you lights on the fogs are off, annoys the crap out of me. What you can do is elliminate the ETACS and get a Relay and some wire, along with quite a bit of elbow grease. No The button for your fogs is just a return type, not a stick. (in other words its not a switch its a conventional button) Making it, ironicly, verry unconventional in this case. So unless you find a Relay or some sort of computerized module to control the fogs your gonna have to get a switch. (I guees your starting to see why no one has made their fogs work like this yet) Don't forget to connect the wire to goes to the dash to illuminate the Fog indicator lamp to some source so when your turn the fog lights turn on soo does the lamp. After that its pretty much done. Cons to this are Obvious, Alot of work, Warranty will be long gone (probaly already is), and if you push the switch at any time the lights will turn on (even if the vehicle is turned off).
