305whp Thats It??
Old Jan 2, 2007 | 03:30 PM
  #61
6-speed's Avatar
Originally Posted by Epidemic
I made 279 hp and 285 tq at buschurs with a custom tune w/ecuflash mods are 21psi, 93 octane ,2.3 stroker, intercooler and lower ic piping, TBE w/test pipe, 264 cams from hks, and ats clutch. I always thought my dyno numbers were low. My afr max was 11.5. What do yall think about my numbers? And buschurs dyno is a mustangdyno.
That's low even for Buschur's dyno, which reads anywhere from 10% - 15% lower than an average DynoJet.
Your torque numbers look low too, even with the stroker.
Off topic BTW.
For the OP:
Evom is great to find help on various questions but please provide as much relevant info as you can.
A dyno chart would be nice too.
Old Jan 2, 2007 | 03:50 PM
  #62
Akisan2's Avatar
Not to thread jack
I have a very similar problem with my IX SE
I got 3 " TBE, Walbro, AEM intake, hallman set to 21 psi at 3rd gear, A/F set to 11:6 ish, very cold day, tuned by local tuner, and defi's boost reading at PSI
Best I got was 295whp/290tq on DYNOJET
Then I realize that on 92 octane I can run up to 23 PSI ish, and the tuner did not do any timing. So with all those I should be close to 320-ish on dynojet which sounds ok to me.
At the time of the tune, the engine was producing knocks and the tuner said he didn't feel comfortable pushing the car, so he eliminated the knock and didn't touch the timing.
I am going to get New plugs(1 step colder), magnacor wires, an oil change and try again.
....Am I on the right track?
Old Jan 2, 2007 | 03:52 PM
  #63
thebluesky's Avatar
That sounds about right given your mods, especially on a mustang dyno which reads low to begin with.
Old Jan 2, 2007 | 03:54 PM
  #64
Epidemic's Avatar
I have no way to scan the dyno chart but i have pics. I dont know how to post them though, when i click on manage attachments it doesnt go anywhere.
Old Jan 2, 2007 | 03:58 PM
  #65
nObject's Avatar
I have an '05 8 with 300+ with no cams and dynoflash tune at The Shop in norwalk but before there was an '03 8 with HKS 272s and with a bushchur stage 3 I believe and it made 315... food for thought
Old Jan 2, 2007 | 04:03 PM
  #66
Epidemic's Avatar
[IMG][/IMG]
Here it is the clearest shot i could get on the bottm the max is 285 tq in blue 279 hp in red 11.5 afr in black and 21.9 psi in grey
Old Jan 2, 2007 | 04:06 PM
  #67
tkklemann's Avatar
I dunno, I dynoed on a Mustang and put 300hp/300 torque.
Here are my mods:
Very SLIGHTLY ported turbo
3" TBE w/ No cat
Boost controller set to 21psi
Full I/C pipe set
Intake w/ TurboXS Maf adapter & Filter
HKS SSQ BOV
Walbro 255
Custom Tune
Those are the only real power adders I have..
So, I would think that my 300/300 would be really good for my mods,
but for yours, especially having cams and an AEM to me it seems a little low.
:Butthenagainidunno:
Old Jan 2, 2007 | 04:10 PM
  #68
SPEED's Avatar
Originally Posted by Bo'sEvo8
Well, from what I recall I think AMS said their dyno is pretty accurate..So I guess 301whp is my whp# don't matter though I can still keep up with a 500hp C6 vette!!
C6 Z06? I like to see you try. Sorry for the OT, i'm calling bs on this.
  #69
Warrtalon's Avatar
Guys, please stop asking about your power - make your own thread and stop thread-jacking.
Akisan2- do NOT get Magnecor wires. I have no idea where you'd get the idea to buy and install those wires. I repeat, DO NOT DO IT. Also, you said "a local tuner" yet he didn't touch timing and didn't diagnose the knock. Well, I would hope you'd realize that means he's not a real Evo tuner and has no idea what he's doing. You should go to a real Evo tuner - not sure why people are starting to cheap out and go with all these newbie tuners using EcuFlash. It's a very, very bad idea...
Old Jan 2, 2007 | 04:12 PM
  #70
thebluesky's Avatar
Originally Posted by Akisan2
Not to thread jack
Going with the colder plugs is a idea I can agree with. Personally though, I'd stick with the stock wires over the magnacores. I've heard mixed reviews and have had mixed experiences with them. The oem wires are actually perform pretty well. But to each their own.
11/6 is slighly leaner than some tuners like. 11/5 is considered safe. I've run 12/0 before with similar mods and 24 psi on 93oct and stock timing before without a knock issue before. I have currently found that the car really likes to be at around 11/5. Anything leaner than that I actually lost power. If you're seeing knock, it'd be a good idea to richen it up a little.
Old Jan 2, 2007 | 04:16 PM
  #71
thebluesky's Avatar
We think alike.
For the record, occaisonally we do .
Old Jan 2, 2007 | 04:18 PM
  #72
Warrtalon's Avatar
No, don't just randomly richen the car because it's knocking. Knock is not solely caused by AFRs. It's a combination of AFR, timing, boost, ambient temps, spark, turbo efficiency, octane (and probably other factors, too). You need to find out what is causing the knock, especially if timing was not increased, rather than just richen the AFRs. Anyway, this should be in a separate thread.
Old Jan 2, 2007 | 04:27 PM
  #73
Akisan2's Avatar
Well, yes I kinda realized after, but hey you live and learn.
Ok, no wires
And I am thinking about Turbo XS UTEC, later in the springtime.
At the moment, I felt that this local shop was a decent place, which they are, but after all said and done, I felt it could have been better.
Either way I still have space to play so that'll be the next fun part of the project.
Thanks for the input
Old Jan 2, 2007 | 04:47 PM
  #74
TxEvo8's Avatar
LOL, this thread is out of control...
Old Jan 2, 2007 | 05:33 PM
  #75
Warrtalon's Avatar
UTEC? Ugh, no, man...come on, where are you getting these ideas? I don't even know how a noob would even THINK of or hear about using UTEC now that EcuFlash is out. EcuFlash is a FREE flashing program that DIRECTLY modifies the tune in the ECU, not an expensive piggyback that just manipulates inputs to the ECU.
Just get flashed by an expert Evo tuner - simple as that and very inexpensive.
