5.5 quarts of oil??
Old Feb 9, 2007 | 04:56 AM
  #31
DanJ's Avatar
Originally Posted by evilution8
hey fellas i cant read the dipstick either. just did an oil change and the oil is so clear that i cant get a good read on it. i put just over 4.5 in now. i have to go to the gym so that should be good for now. i guess ill check it again in the morning when its cold and has been sitting. maybe then ill be able to see how far up the oil comes on the stick. crappy dipstick.
The oil gets pretty dirty quickly (dirty as in color). Because it mixes in with the oil from the oil cooler and whatever is left in the lines. You'll be able to see it very clearly soon. However if you look closely you can tell right after the oil change just look for the shiny/wet line it creates. might want to take a flashlight to it.
Old Feb 9, 2007 | 05:07 AM
  #32
mifesto's Avatar
lets see... u shouldnt be even putting in a full 5 quarts. its quite hard to remove all the oil, some is in the oil cooler and some are in the engine itself. 5.5 is WAY too much. w/ evo (and most cars) u should be starting w/ about 4.5 quarts. ur already at a very safe level (almost 5qts) then tape a dip stick reading. add slightly more to hit full, ur done.
i'll be frank, if u or ur friends cant do an oil change without stripping the drain plug(used open ended wrench?) or putting in the wrong amount, maybe u should have a friend who DOES know cars to teach ALL of you guys.
Old Feb 9, 2007 | 05:08 AM
  #33
SteveosEvo's Avatar
Originally Posted by TheTumblerIX
He probably just stole a quart of your oil.
That was funny . I guess he did not steal it if it was high.
Old Feb 9, 2007 | 05:51 AM
  #34
EVO8emUp's Avatar
how the eff do round off a drain plug?
Old Feb 9, 2007 | 12:40 PM
  #35
fevo's Avatar
buy a hand pump and pump it out from dip tunnel ,
tht was wht I did ...
try pump into a spring water bottle instead of a coke bottle =p
Old Feb 9, 2007 | 12:44 PM
  #36
mifesto's Avatar
probably w/ an open wrench
Old Feb 9, 2007 | 02:05 PM
  #37
evilution8's Avatar
17mm worked perfect on the drain plug. got it off easy and made sure not to overtighten it when i put it back on, i dont have a torque wrench. anyway you were right about the oil dirtying up a little. i drove a short distance last night and it mixed with oil still left in the lines. this morning while cold, i took that dip stick out and could see plain as day. the line came right up to the second (full) notch on the dipstick, and that was just over 4.5, maybe 4.75 quarts. looks like i guessed right. no big deal to add some if i had to, just didnt want to drain, it would be a pain in the ****. anyway thanks guys.
kosteniuks17
Jan 20, 2014 11:53 AM
jsfour
Apr 27, 2006 10:44 AM
evolver
16
Jun 10, 2004 06:01 AM
chase
Feb 13, 2004 08:08 PM
Trbo Dad
14
Dec 14, 2003 02:10 PM
