Mini battery kit for ~$50?? I think so! *PICS*
Old Feb 21, 2007 | 02:02 PM
TVA's Avatar
TVA
UPDATE #3
Changed out the negative terminal for something a little more aesthetically pleasing and picked up my postive terminal cover from the dealer. Still working like a champ.
UPDATE #2
We got 4" of snow for the past 2 days and temperatures ~28-34*. Battery worked perfectly without a hitch.
UPDATE #1
I've changed my design a bit, as you can see.
I decided that I didn't want to pay a major premium for a mini battery kit as my stock one started to go. I started with an Everstart ES50N18LA3 lead-acid motorcycle battery rated at 260 cold cranking amps. (*note* You'll need to fill the battery with acid which is provided with filling tubes.) Next you'll need a pair of threaded automotive battery posts. Both items were purchased at Wal-mart for ~$50. I had to fab up a pair of brackets to connect the motorcycle-style terminals to the battery posts. A couple pieces of aluminum cut and drilled to fit worked perfectly. The J bolts that hold the battery tie down had to be cut about a half an inch and re-bent into J's. This was accomplished with a hacksaw and a vice. Here's the result.
Battery part number
Positive post with bracket
Negative post with bracket
Overhead
Driver side
Driver side overhead
Passenger side
Overall I lost about 15lbs off the front end and it starts up just as well, if not better than stock. Its not turned parallel with the car due to being a bit to long for the factory tiedown to cover to top. Let me know what you guys think.
Old Feb 21, 2007 | 02:08 PM
EVO8904's Avatar
I think its not bad for $50 and you need to change that air filter.
Old Feb 21, 2007 | 02:09 PM
sandm's Avatar
Ghetto.
Old Feb 21, 2007 | 02:10 PM
althemean's Avatar
looks like a cheap mod.....
Old Feb 21, 2007 | 02:11 PM
TVA's Avatar
TVA
Yeah ordering one now.
turboDan's Avatar
With that exposed + battery terminal/adapter it looks like a Fire just waiting to happen
Old Feb 21, 2007 | 02:12 PM
anjapower's Avatar
Originally Posted by sandm
Ghetto.
+1000
Old Feb 21, 2007 | 02:13 PM
.50 Cal Cow's Avatar
it is a cheap mod. only $50.00
Old Feb 21, 2007 | 02:14 PM
TVA's Avatar
TVA
Well it was. Functional too.
Old Feb 21, 2007 | 02:16 PM
Turbo Kyle's Avatar
Nice!
Old Feb 21, 2007 | 02:17 PM
TVA's Avatar
TVA
Working on covers next.
EVO8904's Avatar
I think it might only cost $50 to relocate it to the trunk...
Old Feb 21, 2007 | 02:19 PM
TVA's Avatar
TVA
Well I'd need a better/different tiedown, battery box, added hassle of running power through the cabin. Nah.
Old Feb 21, 2007 | 02:20 PM
nigletsyz's Avatar
too bad yours doesn't change the orientation of the battery so aftermarket UICPs will fit.
Old Feb 21, 2007 | 02:21 PM
TURBevO8's Avatar
How is this functional? What purpose does it serve? From the looks of that you can not run a shorter UICP. So what then? Weight reduction? If you say yes then....well I am not like some people on here......so I guess I will just keep my thoughts to myself.
