My oil change adventure...
The basics: Viscosity is the measure of how thick a liquid is. Oils have a higher viscosity than water (they flow slower). A higher viscosity oil helps keep moving parts apart, but too high and your oil system may have trouble pumping it and the oil will have trouble flowing into the smaller crevices that it needs to lubricate evenly.
Regular un-enhanced oils are rated by their viscoity, the 'weight'. This is the W number. 10W- 5W- etc. (For the record, W stands for Winter, not weight. The number is the viscosity of the oil at 0C [32F]. ) Multi-viscosity Oils have two numbers (i.e. 10W30).
Now, as oils heat up, their viscosity goes down. A motor oil that will flow properly for your engine when cold will be useless at operating temp. So they add long molecules called polymers that are all bunched up when cold, but unwind when hot. That increases the viscosity.
So, the second number in 10W30 is the equivalent viscosity at 100C [212F]. So a 10W30 oil at 100C is the same viscosity as a 30W oil at 100C.
The balance you need is an oil that's thin enough to flow properly when the engine is cold, but thick enough at operating temps to maintain the needed viscosity.
EDIT: Forgot to mention. There's a lot ofargument about the really diverse multi-viscosity oils (i.e. 0W50). A lot of people think the longer polymer chains needed to get a spread like that can be broken easier, so you need to change it more often in high-load applications.
Great explanation here. Read this people, because many here have misconceptions about oil weights. A proper ester-based, group IV synthetic in 0W-50 encapsulates the entire operating range of a similar based oil rated at 10W-30. However, you have the added protection at extremely cold starting temperatures or extremely hot operating temperatures. I can see no fault from using a 0W-50 synthetic.
On a side note: most car manufacturers will only recommend one type and brand of oil due to licensing agreements with an oil supplier. This has absolutely NOTHING to do with engine performance, longevity or protection; rather what makes the auto manufacturer the most profitable. You can't have a contract with Mobil or Castrol, then very well recommend any synthetic oil in a similar viscosity range. If they do that, the auto manufacturer will be in breach of their contract with whatever oil manufacturer they happen to be in partnership with. And as well know, is bad joo joo for business. Think about it guys... it's not rocket science.
With my M3, I changed tranny and diff oil at 1200 miles per manufacturer recommendation. I figured changing the drive train fluids on the Evo wouldn't hurt either... and in this case, I'm glad I did. The tranny, diff, and t-case oil was very dark, and there was a lot of sludge and magnetic residue around the drain bolts.
clifhanger87
46
Oct 30, 2016 07:11 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
chaotichoax
Feb 7, 2010 10:20 PM
