Weird speedometer problem
Old Jun 5, 2007 | 06:32 PM
mrdevo's Avatar
I was getting on the car hard for the first time in a while and noticed, again, that under full boost the needle for the speedo jumps literally from 65/70->80 mph and then from 110/115->130. The car accelerates fine, it's just that the needle hesitates and then jumps to where it should be. Has anyone else had this problem? I guess it's not that big of a deal since I watch the tach too.
Old Jun 5, 2007 | 07:29 PM
CWNEVO's Avatar
My speedo is fine, but my tach sticks for some reason. ill be drivin around and look down, and itll say 0 rpm's. Afew taps on the dash and its good. They just seem to stick.
Old Jun 5, 2007 | 07:47 PM
4rcd6's Avatar
its from all those ballz you got under the hood... speedo cant keep up LOL! JK i have no idea
Old Jun 6, 2007 | 06:54 AM
mrdevo's Avatar
ye my tach has always been ok, my speedo needle just sticks at certain points and then it recovers. Lol I really don't want to bang the dash while under full boost at 100+mph
Old Jun 6, 2007 | 07:27 AM
zeus1's Avatar
my speedo used to jump all over the place..had to get a new gauge cluster..that fixed it..under warranty
Old Jun 6, 2007 | 07:32 AM
JohnnyBoy427's Avatar
mine used to do that but my speedo needle was pushed in too far. i pulled it out a bit and have had no problems since
Old Jun 8, 2007 | 06:22 PM
CWNEVO's Avatar
Yeah, I can honestly say I dont blame you.
Old Jun 8, 2007 | 08:30 PM
1mpak7's Avatar
get a turbo timer, dunno if they all do it, but my HKS projects the digi speed, lot nicer.... plus it may benefit the turbo lol
Old Jun 9, 2007 | 01:05 AM
ex10psi's Avatar
Registered User
i've never seen this happen on my evo but on an old accord i had a while back... this happened and i had to replace the whole gauge cluster. got it from the wrecking yard for cheap. you might consider that if you're out of warranty
austin_davee
Dec 17, 2016 07:19 AM
rogerlam
Dec 27, 2015 04:55 AM
NYrEvolution
23
Sep 21, 2006 12:05 PM
858SD
Jan 28, 2006 07:17 AM
Z_Lancer_Man
Lancer How Tos / Installations
Apr 21, 2005 04:15 PM
