Greddy UICP
Old Nov 13, 2007 | 06:25 AM
philevo's Avatar
Greddy UICP
I just got the Greddy UICP and I just wanted to know, what that second bung is used for? The first one is for re-circulating the blowoff valve and the second bung seems to do nothing. My friend suggested I fill it with apoxy so it can be re-tapped for somthing else.
In this picture its the 1st bung and the 2nd is for the BOV:
http://www.stikiller.com/product.php?productid=16299
Old Nov 13, 2007 | 09:32 AM
alby988's Avatar
its for the anti-lag on the jdm cars.
cap it off and its all good!
Old Nov 13, 2007 | 11:30 AM
Evo8Emperor's Avatar
I have the same pipe and unless you weld a piece of aluminum over the bung then i bet your going to get a boost leak. It may not be a lot but it does. I did a test on my system and that was a leak i ran into.
Old Nov 13, 2007 | 11:48 AM
JDMCT9MR's Avatar
What about some type of rubber or silicone cap with a clamp?
Old Nov 13, 2007 | 12:38 PM
philevo's Avatar
Thats exactly what I was thinking, but my mechanic said it could tear since I want to get a bigger turbo and run a lot of boost. So what he did was cut the unused bung shorter, put in a brass plug and filled it with apoxy. Looks like sh*t but he said it will do the job better.
Old Nov 13, 2007 | 12:42 PM
If you really want to make sure you have no head aches cut the bung off at the pipe and just bring it to any aluminum shop where they could heli arc a plate on for you.
Old Nov 13, 2007 | 12:49 PM
ducker's Avatar
Does that pipe fit with the stock airbox/intake.
Old Nov 13, 2007 | 12:52 PM
DG Motors's Avatar
It is for an "intake air temperature" sender for when/if you go stand alone.
edit: i could be wrong, i did not look at the picture the first time i posted.
Old Nov 13, 2007 | 12:55 PM
jenx1976's Avatar
I just wrapped that second bung with some rubber tape and put a clamp on it...have in on for about 15+k miles no problems.....didnt wanna risk anything getting sucked in at the TB??? altho the boost will probly blow it out if anything.
Old Nov 13, 2007 | 01:02 PM
scoob2evo's Avatar
do it right the first time and weld it shut
Old Nov 13, 2007 | 01:03 PM
Dapper Dan's Avatar
if you just used tape you deffinatley have a boost leak!
Old Nov 14, 2007 | 09:09 AM
philevo's Avatar
No. and the pipe has to modified to fit the stock battery
rajal13
May 16, 2016 02:57 AM
changocox1322
11
Mar 31, 2016 07:41 AM
BlkRVR5spd
Outlander Sport
21
May 4, 2015 07:38 AM
pure_butane
Jan 27, 2010 08:41 AM
evod810
Aug 25, 2006 06:09 PM
