Good Setup?
Old Jan 25, 2008 | 01:31 AM
gixxer6's Avatar
Question Good Setup?
Here's the setup I'm planning on doing, I want around 300whp/tq what do you all think? Walbro 255 fp hallman manual bc HKS Hi-power catback 3"perrin dp mynes test pipe and ecu flash with dyno tune, and I already installed a blitz air induction box/cover
Old Jan 25, 2008 | 02:54 AM
geardog75's Avatar
i dont see why not with a good tune on a mr.
Old Jan 25, 2008 | 07:09 AM
gixxer6's Avatar
Any other thoughts..anyone else?
Old Jan 25, 2008 | 08:21 AM
90GSX-03EVO's Avatar
No need for the Walbro if you're only shooting for 300 WHP.
Old Jan 25, 2008 | 08:35 AM
OMG EVo's Avatar
cams?
Sounds reasonable with a good tune.
Old Jan 25, 2008 | 08:43 AM
Cams would be a great addition if you wanted something more than a peak HP number (a plateau instead of a mountain). I'd recommend the GSC S1 cams.
Also, what kind of gas? 91 or 93 octane?
Old Jan 25, 2008 | 11:36 AM
gixxer6's Avatar
well when I run hard I mix 93 and 100octane race gas? It seems to make a little more power? Is there any reason this is a bad idea?
Old Jan 25, 2008 | 11:39 AM
You're not making more power with higher octane, you're probably pulling less timing (which is allowing you to make the power you originally made when you got tuned).
Old Jan 25, 2008 | 11:44 AM
silver9mr's Avatar
with ur mods and a tune depending on how much boost youll run you should be over the 300 mark easy with out cams
Old Jan 25, 2008 | 11:46 AM
travman's Avatar
My friend's IX made 301 on a mustang dyno with just a magnaflow catback (stock dp & cat), mbc, and drop-in + tune.
So your goals can be easily met with a IX.....
Old Jan 25, 2008 | 07:11 PM
dzraduzit's Avatar
w/ that set-up you'll easily be over 300whp and tq
Old Jan 25, 2008 | 07:18 PM
CGK's Avatar
CGK
Agreed with everyone else...you will break the 300hp mark pretty easily.
DirtyEvo9
Mar 10, 2015 03:03 PM
motoxxx55
Nov 15, 2009 05:09 PM
EVOlutionary
Feb 29, 2008 09:07 AM
RalliArtEvoVIII
Nov 18, 2006 07:52 AM
umiami80
11
Nov 2, 2003 09:22 PM
