Engine Sputtering at Max Boost
Old Feb 7, 2008 | 11:29 AM
figuerda's Avatar
Hi guys, my evo 8 is sputtering when you boost reaches 19 psi and I have a check engine light on. No other symptoms. Could it be the spark plugs? I changed them a year ago for iridium plugs. Is that what the car would act like it one was fouled?
thanks
Old Feb 7, 2008 | 11:54 AM
chaotichoax's Avatar
it's possible
but you need to pull them and take a look
Old Feb 7, 2008 | 11:55 AM
philevo's Avatar
If the car has been tuned, it may be plugs and wires...
If the car has NOT been tuned, get a tune.
Check to see what code the car is throwing
Old Feb 7, 2008 | 11:56 AM
KillaItalian904's Avatar
if the car has not been tuned than it is def fuel cut... very common
Old Feb 7, 2008 | 12:09 PM
tabio42's Avatar
a year is a long time to go without cleaning your plugs
Old Feb 7, 2008 | 01:12 PM
andrewzaragoza's Avatar
get your error code read at autozone to see exactly why it is going off.
Old Feb 7, 2008 | 01:27 PM
lemmonhead's Avatar
could it be the EGT system. But then again isn't it suppose to completely shutoff at WOT or high RPM.
Old Feb 7, 2008 | 01:40 PM
KS_Evo9's Avatar
If im in 6th gear at low rpm like 2k and floor it, it sputters due to to much load. That could be your prob but it did this after I installed my Hallman and uppd the boost to 23 pounds.
Old Feb 7, 2008 | 02:32 PM
Ev0cRaZy's Avatar
Misfire code I bet.
Change your plugs, year is a long time. Cheap fix you know.
Old Feb 7, 2008 | 03:05 PM
RPRalliart04's Avatar
Yea, I am a new evo owner and am having the same problem. At WOT, from around 4500-6500rpms, the car sputters intensely and if i stay on it then i get a popping sound. So after a little searching I came to the conclusion that there is a good possibility its the plugs and wires (which are still stock btw at 37k miles).
And my car does have the basic vishnu ecu tune, i believe the XEDE, and the guy I bought it from bought it that way as well and he was told it was all properly tuned. So today went and ordered new NGK iridium plugs and the NGK coil wires. So hopefully that solves my problem and hopefully yours too.
Old Feb 7, 2008 | 03:07 PM
gixxerman11's Avatar
sounds kinda like fuel cut maybe
Old Feb 7, 2008 | 06:59 PM
10SEKNDMR's Avatar
i was having the same problem....so i took it to my tuner and added a fuel reg and a new fuel rail with new plugs and got it re-tunned and that was the end of that problem.PROBLEM SOLVED....
jrmav32
Jul 3, 2017 11:44 AM
papabeardoe
Jun 13, 2017 04:06 AM
Igaly1021
Nov 7, 2015 05:18 PM
vxevolutionxv
11
Jul 6, 2009 09:37 PM
10SEKNDMR
Nov 11, 2007 10:55 PM
