Car Does Not Start Anymore....
Old Mar 26, 2008 | 04:23 AM
nplatenkamp's Avatar
Red face Car Does Not Start Anymore....
Hello,
I have a problem to start the car. (USDM)
I wanted to copy my only key and they checked it and told me they cannot do it, but now the car does not start (also no gong/buzzer anymore).
I tried to disable the immobilizer with 0000 and FFFF but still nothing...
Everything works ok, but when I turn to start the voltage goes to 0 V but
the battery still has 12 V. (startmotor does not turn)
Before I could start it with no problem. Is the key code modified or is something
else a miss ?
Can anyone help me please ?
Old Mar 26, 2008 | 06:01 AM
EvolNinja's Avatar
I hope you don't have to take it to the dealer. It's probably the key if everything in the car is ok. Good luck
Old Mar 26, 2008 | 06:18 AM
PVD04's Avatar
Your clutch switch may have slipped and is not getting pressed when you push the clutch down. Check that and see if you can get it to turn over. The immobilizer won't effect the starter motor, so that is not the problem.
-Paul
Old Mar 26, 2008 | 06:30 AM
ekizenbe's Avatar
yea like the previous poster said, go under the dash and disconnect the clutch switch, it takes one more thing out of the loop. Now your car will start without having to push the clutch down. be carefull
Old Mar 26, 2008 | 06:45 AM
Redline-Z's Avatar
Veteran: Air Force
do you have a green key symbol on the dashboard? Also you can key a spare yourself if you have the 2 original keys.
Old Mar 26, 2008 | 06:50 AM
Clutch
Ok, thanks i will try the clutch switch tonite.
Old Mar 26, 2008 | 10:03 AM
RoadSpike's Avatar
FYI setting your immobilizer code to 0000/FFFF does NOT disable the anti theft device. You have to do that in the ECU periphery settings.
Old Mar 27, 2008 | 12:05 AM
Not start
Thanks a lot guys!
It was the clutch switch. I never had a car which is in neutral gear can
not start...
So after putting the clutch down it fired right up.
Thanks again for the fast and superb advise!
xjy19860421
Jun 18, 2016 11:09 PM
ashspark101
04-06 Lancer Ralliart How To Requests / Questions / Tips
29
Jul 25, 2014 07:43 PM
MurderedOut09
Jan 23, 2014 12:35 PM
umopp
Jun 22, 2012 12:27 PM
GusandoX
Jun 6, 2011 07:32 PM
