I have a CEL after installing 3" DP?!?
Old Apr 8, 2008 | 10:00 AM
EvolNinja's Avatar
Ok, I got done with installing my 3" DP and Cat-delete lastnight. I took it for a drive with my wife around town and back. It seems fine. Today, I stop by the gas station and fill her up. It might be because I remove the gas cap before the engine is off but I did that before and nothing happens. I think it's because the DP is too close to the oil pan and tranny. When I get to work today, the CEL came on. I think the CEL is the "Service Engine Soon"??? Any ideas??
Old Apr 8, 2008 | 10:02 AM
sleeper3's Avatar
May be an obvious question but did you do something to alter the reading of the second O2 sensor now that the cat is gone?
Old Apr 8, 2008 | 10:03 AM
Redline-Z's Avatar
Veteran: Air Force
Yes and the code is P0420 and he needs a O2 fix.
Old Apr 8, 2008 | 10:04 AM
vvhiteix's Avatar
your rear o2 sensor...needs to be further away from the exhaust gas...people sell them, here on the forum...i think i might actually have one....pm me
Old Apr 8, 2008 | 10:05 AM
Redline-Z's Avatar
Veteran: Air Force
I bought my 2 at advance for like 5 bucks and drilled it out. There are numerous threads in the How-to secction.
Old Apr 8, 2008 | 10:07 AM
vvhiteix's Avatar
yea...i bought mine at like pep boys or advanced...just forget the part numbers...but yes...the how to section will have it. so just check it out..
Old Apr 8, 2008 | 10:09 AM
EvolNinja's Avatar
I dont' think I did anything to alter the O2 reading except that I remove the Cat so maybe there's too much hot air going to the second O2 sensor.
vvhiteix, so that means I have to seal the second O2 sensor bung and make a new one at a farther down the pipe?
Old Apr 8, 2008 | 10:13 AM
EvolvedGTI's Avatar
What they are saying is you need to get two anti-fouler, drill them out and screw that into the second O2 bung. You then screw the O2 into this. This makes the O2 reads less of the gas, and the light will go away. Search for "O2 fix". it is really easy
Old Apr 8, 2008 | 10:15 AM
sleeper3's Avatar
Like EvolvedGTI is saying, you can use the existing second O2 sensor bung, and install an anti-fouler plug that recesses the tip of the O2 sensor away from the exhaust stream. It usually looks something like this:
Old Apr 8, 2008 | 10:18 AM
grillpt's Avatar
Your computer is sensing that you've removed the cat from your car. It doesn't matter where you bung it in, you don't have a cat. If you don't want to get the mechanical fix from PepBoys or Advance Auto, (which I couldn't because they didn't have any big enough) you can order them through Gruppe-S for like $13 shipped. Thats what I did.
Old Apr 8, 2008 | 10:19 AM
EvolNinja's Avatar
Thanks to you all for your advices! Greatly appreciated for the quick help.
Old Apr 8, 2008 | 11:18 AM
c_sautter's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=208195
I bought mine at NAPA, the part number was cross referenced. I followed the "how to" and it works.
Old Apr 8, 2008 | 11:26 AM
philevo's Avatar
just buy a CEL fix you will be fine. I had the same problem.
Old Apr 8, 2008 | 12:38 PM
BBS's Avatar
BBS
Remember that this is a very primitive way to trick the car into thinking that the cat is still there. You may still throw a cel
DormantBeast
44
Jan 29, 2011 08:32 PM
supersupra
11
Sep 12, 2006 08:08 PM
use2vtec
26
Mar 21, 2006 09:57 PM
nnorris7413
12
Feb 9, 2006 02:40 PM
TRDHarrier
15
Dec 15, 2003 07:46 AM
