Maximum Boost
Old Apr 14, 2008 | 05:37 AM
moey124's Avatar
Maximum Boost
What is the Maximum Boost you can run on your Stock EVO IX MR?
TeStUdO's Avatar
50lbs
Old Apr 14, 2008 | 05:41 AM
jmelocik's Avatar
^ LOL OP with or without meth?
Josh
Old Apr 14, 2008 | 06:20 AM
Burklow's Avatar
Ohh boy.
If you're untuned, don't turn the boost up. If you have a tuner, he or she will tell you what to turn it to. Usually not more than 23 PSI with stock turbo, no meth, 93 pump.
Old Apr 14, 2008 | 06:23 AM
staatz's Avatar
I would turn it up to 20psi on a mbc, call it a day.
Old Apr 14, 2008 | 07:31 AM
lemmonhead's Avatar
you can turn it up to 25psi, just see how high before you car knocks. 23psi is conservative, 25psi would be a good.
Old Apr 14, 2008 | 10:11 AM
EvoJoeIX's Avatar
i beleive the max for the stock turbo is around like 32psi.... not 100 percent sure. but that is the MAX, highly recommend you dont run that kind of boost
Old Apr 14, 2008 | 10:17 AM
Redline-Z's Avatar
Veteran: Air Force
True..I am holding 23-24 with a mid 25's spike and zero knock on 93 octane. It depends on the tune.
Old Apr 14, 2008 | 10:24 AM
TonyG's Avatar
OP: race or pump gas?
Old Apr 14, 2008 | 10:27 AM
06MRV8Killer's Avatar
I just got retuned this weekend by 4WS. I'm currently running 25psi but I have the mods to support it. If you are looking to turn up the boost without a tune I wouldnt do it. If you must do so then I would do no more than 20 psi.
If you are getting tuned and just need to know the max boost with no mods you need to just shoot for as much as you can with no knock.
Old Apr 14, 2008 | 10:40 AM
chaotichoax's Avatar
search...
Maximum Boost
33
Mar 26, 2006 07:40 PM
11secEVO7
Jul 27, 2005 02:00 PM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
17
Oct 7, 2004 03:07 PM
evo4.5
Nov 24, 2003 07:39 PM
ex-honda
26
Oct 31, 2003 05:13 PM
