Low Vacuum Solutions?
Old May 29, 2008 | 06:10 AM
ThEHiTMaN's Avatar
My car suffers from very low vacuum. HKS cams it was around -7psi with the BF's it is around -4 to -5 with the AC on forget about it... My question is A) how can you boost vacuum on a stock ecu car? and B) does using an AEM EMS allow more vacuum to build with a big cam like I have? The car idles fine but with quick clutch in it will not like that and is usually a total pain in the *** to start back up. Setting the idle at 1200+ rpm also does nothing. It has the problem that most have when you put the clutch in fast and get on the brakes while stopping. It is just 10X worse with these big cams. I know these cams are not suggested for stock ecu cars but what does the AEM offer that the stock ECU does not to catch it before it stalls out?
Old May 29, 2008 | 09:19 AM
mplspilot's Avatar
Have you tried advancing timing a bit at idle?
Old May 29, 2008 | 02:49 PM
ThEHiTMaN's Avatar
Yes
Old May 29, 2008 | 04:27 PM
gsrboi80's Avatar
What is the idle timing set to?
Plus
You should be able to tweak those idle stepper tables and get it dialed in. Mellon should be able to mess with them im sure
-4 to -5 damn
Old May 29, 2008 | 05:51 PM
Evo8Emperor's Avatar
I dunno i run hks 272 intake and exhaust cams and the jdm map sensor is logging usually -5psi at idle. My idle is around 900 and I have never had a problem.
Old May 29, 2008 | 05:55 PM
Mellon Racing's Avatar
Dustin that vacuum isn't that low, mine is -5 to -6 with the HKS 280's at 1000rpm...send me some logs of it stalling and maybe I can isolate the problem.
Old May 29, 2008 | 06:19 PM
keeler's Avatar
The vacuum is about right for the cams, play with the tune and timing and you might be able to get more
Old May 29, 2008 | 11:50 PM
ThEHiTMaN's Avatar
ok chris I will try to get u some. thanks for ur help!!
Old May 30, 2008 | 07:44 AM
cool, I'll keep an eye out for them
My03evo
Jun 29, 2011 08:51 PM
Guru
16
Aug 13, 2010 09:59 AM
ThEHiTMaN
31
Apr 29, 2008 10:54 AM
DS-03evo
11
May 21, 2007 06:57 PM
DarksideEng
18
Jan 10, 2006 03:32 PM
