Do evo 8 have 2 step
Old Jul 2, 2008 | 01:31 PM
  #31
vmrevo9's Avatar
Veteran: Air Force
Originally Posted by LeosEvo
2step for evo 8 or 9 is the same exact thing... and its weird that he could have a 2step without having the clutch pressed all the way in ''I NEVER HEARD OF THAT BEFORE''.... and if you have 2step while the car is moving you would never be able to get even close to redline lol....
well i thought it was wierd as well. but apparently it's normal. he has an 03 and his ecu reads to be an 04 which i also found to be normal.
the 2step is not activated while the car is moving!!! while the car is stationary (hence stationary rev limit) it activates the 2 step. now i found it wierd that the clutch wasnt pressed in while we were testing it but it work fine and the car would be able to launch. once moving the car was able to reach redline which we had set to 7500 at the time.
Old Jul 2, 2008 | 01:33 PM
  #32
vmrevo9's Avatar
Veteran: Air Force
Originally Posted by def1
how can be a 2 step be set past redline? Who launches there car at 7600 rpms?
I think you guys are thinking of the rev limiter not a 2 step.
this could have been a disable feature from the factory. and of course it can only be "enabled through a flash.
they are clearly marked in the ecu
rev limit.
Old Jul 2, 2008 | 03:05 PM
  #33
Tuner@Swift's Avatar
For those who can't understand something without seeing a picture:
The 2-step is labeled as "stationary rev limit and the normal rev limit is labeled as "rev limit." 03'-04's have the 2 step set above the rev limit, thereby preventing he 2 step from being used. Anyone with a tactrix cable and ecuflash can change this value to something less than the rev limit to enable the 2 step.
Old Jul 2, 2008 | 04:54 PM
  #34
vmrevo9's Avatar
Veteran: Air Force
^^^ thank you!!
Old Jul 28, 2008 | 07:32 PM
  #35
jaysonmyfeet07's Avatar
Originally Posted by ibarkovic
My friend has a bby evolution 8 , and i was surprised that he didnt have 2step on his car, he never knew wat it was and thought i was lying cuz i thought that all evos came with factory two step , by the way he upgraded his clutch but he said he didnt have the 2step before either , alright thank you ,
yea... dats me...
and i told u i didnt have 2 step biatchhhhhh!!!!1 lol
Old Jul 29, 2008 | 08:36 AM
  #36
BlueEvo61106's Avatar
My 2 step is at 5500rpms. It launches pretty well with the modes I have. Never been to the track yet though.
Old Jul 29, 2008 | 08:48 AM
  #37
neonglh's Avatar
Yup, my '03 has it, from a reflash. 0 mph and WOT holds the rpm at 6k rpm. We also bumped up my rev limit to 8k
Old Jul 29, 2008 | 09:20 AM
  #38
evo8426's Avatar
Originally Posted by jaysonmyfeet07
yea... dats me...
you do have one, refer to post #33
Old Jul 29, 2008 | 09:48 AM
  #39
compscibOi's Avatar
no evo 8 do not has 2 step mkay!?
Old Jul 29, 2008 | 09:52 AM
  #40
redboosted05's Avatar
I have always been having a problem my two step never worked even when flashed and I have an 05 evo 8 something is messed up with my computer-Joeyd
Old Jul 29, 2008 | 10:05 AM
  #41
EVO IXMR's Avatar
Originally Posted by nightwalker
all U.S. EVOs have a "2 step". I have an 03 and I have mine set to 4800
then your car was tuned...2 steps were put in us evo's after 2005
Papa_Dragon
Apr 28, 2017 05:56 AM
rydogg008
Evo X How Tos / Installations
11
Jan 31, 2015 06:19 PM
audiofan
Apr 3, 2011 05:36 PM
Boostme
18
Mar 9, 2009 06:02 PM
sekula
Sep 13, 2007 01:47 PM
