e85 thoughts ?
Old Sep 21, 2008 | 04:18 PM
  #31
rob17san's Avatar
lots of us in denver are running it. I will be soon. No one has issues.
Old Sep 21, 2008 | 05:04 PM
  #32
CleverUserName's Avatar
Originally Posted by Jim in Tucson
Minimum of 850cc, but I suggest 1,000cc. If you plan further turbo upgrades you might want to jump to 1,200cc.
i'll check the alternative fuel section too, but i'm curious what tuners think about running 1200cc injectors on stock ecu. also, at what point will a 255 walbro be insufficient, assuming 7800 rpm fuel cut?
Old Sep 22, 2008 | 01:06 AM
  #33
sprx19's Avatar
I ran it in my wrx and was a little harder to start in the winter, but not enough to be an issue.
Old Sep 22, 2008 | 04:00 AM
  #34
DIDYSIS's Avatar
I am going to be setting up to run E85 soon, also going to be moving so will wait for that, I saw a device in another post that showed the percentage of mix and I am thinking that will be a must for the cold weather and mix changes.
Old Sep 22, 2008 | 05:10 AM
  #35
emilebazin's Avatar
e85
DiDYSIS What device is that, What else is need to ruin e85
Old Sep 22, 2008 | 05:23 AM
  #36
Jim in Tucson's Avatar
Search in the ECUflash section. A lot of EVOs running 1,200cc injectors with stock ECU. I wold not, however, unless you are running a larger than stock (>=FPred) in which case you would also want a twin pumps set-up or a supplemental pump.
Old Sep 22, 2008 | 06:21 AM
  #37
andreww238's Avatar
if i had an e85 station close.. id def do it
Old Sep 22, 2008 | 06:35 AM
  #38
ah yes, the double pump setup. guess i'll have to look into how pricey such a step will be. i have a lot of learning to do, i want a dual setup where i have my pump gas map in case , then i'm thinking about how well the pump map will run with the double pumper and the 1200. compromises, compromises.
Old Sep 22, 2008 | 07:58 AM
  #39
EpicEVO's Avatar
Buschur Racing C.O.P... NGK BPR-7ES Plugs .25 gap.... Runs great just went 10.53@131 this weekend on E-85.. 32psi on a PT "37r" .82 hot side
Old Sep 22, 2008 | 08:15 PM
  #40
mrfred's Avatar
Unless you have plans for more than a Green, only a single Walbro is needed. There are inline pump options as well if you do need more pumping capacity.
Old Sep 23, 2008 | 05:39 PM
  #41
sdfontanini's Avatar
did the e85 tune, 880cc aeromotive rail, 255 walbro car dyno'd at 350whp and 335tq. at 25psi got spark blowout at hi boost hi rpms in 5th gear only so i gapd to 0.019 everything is smooth, lookin to upgrade coils and put in those damn head studs for increased boost. 28psi here i come... a double pumper is def needed for a fp, fuel cut sucs azz. can't wait to do cams next april... next goal is 380whp
jfvhpilot
Aug 7, 2017 08:22 AM
spoolin turbo
E85 / Ethanol
Mar 6, 2017 03:12 AM
turbotaloon95
Apr 11, 2016 06:58 AM
razorlab
Oct 13, 2008 03:31 PM
mrfred
E85 / Ethanol
Jul 3, 2008 07:53 PM
