Two guys, two mods, and a tune... in the 11's
Old Aug 18, 2009 | 01:42 PM
  #481
9sec9's Avatar
Quick answer on the higher mph. I leaned the 6500+ RPM range by .1 to .2 and changed one RPM row in the MIVEC by about .6 if I recall. Since I made both changes at the same time, I'm not sure at this point which did the most good, but I think both contributed to the results. Nearly all of the interval times improved, (60-330, 330-660, 660-1000, 1000-1320) with the only one of them being a few thousandths behind our previous best. The tires were brand new and the 60's were 1.72 I believe, but Indy was out of sync, so not a real good test. Also, the tires need about 25 passes or so to get scrubbed in good. The engineer told me yesterday that the compound is a very tough and resilient, therefore the need for several passes to get them ready for best results.
Old Aug 18, 2009 | 03:51 PM
  #482
EVIL_EV0's Avatar
Is that tune only good on 98 octane?
Old Aug 18, 2009 | 04:35 PM
  #483
9sec9's Avatar
I adjusted it for 101 and added up to 4 degrees of timing. For Jim, we have 93, 95, 98 and 101 tunes at this point. Since I don't change fuels without retuning the car, I really couldn't answer it accurately. We did make one pass with the 98 octane tune, but using 101 and there was 0 knock, so I added the above mentioned timing. In comparison, I like the 101 by far better than the 98. Sorry, EVIL_EVO for not being too definite, but I'm just not sure to be honest.
Old Aug 18, 2009 | 04:45 PM
  #484
EVIL_EV0's Avatar
Thank you for the reply... can you post the mivec map?
Old Aug 18, 2009 | 04:57 PM
  #485
9sec9's Avatar
Let me get a snapshot of it.
Old Aug 18, 2009 | 05:36 PM
  #486
4g63evoeight's Avatar
awesome work guys!
Old Aug 18, 2009 | 06:07 PM
  #487
Indy Evo's Avatar
Launch sequence from the 12.008 pass at Muncie. Photos by Matt Marlow
Old Aug 18, 2009 | 07:42 PM
  #488
9sec9's Avatar
I can beat that:
12.008 Hoosiers
http://www.youtube.com/watch?v=GfmCH36cP2U
12.07 BFG's
http://www.youtube.com/watch?v=176-VgRc_PM
12.03 BFG's
http://www.youtube.com/watch?v=XQC6jfKiZ5M
Old Aug 18, 2009 | 08:01 PM
  #489
Indy Evo's Avatar
As you can see in the videos, we are not killing the car to run these numbers. The 12.008 at Muncie was a soft shakedown pass, and the runs at IRP were in the high 1.6-.7 range for the 60 ft's. Thanks for posting those videos 9sec9.
Old Aug 18, 2009 | 08:23 PM
  #490
FathouseFab's Avatar
Put e85 in that turd already man!
Old Aug 18, 2009 | 08:58 PM
  #491
9sec9's Avatar
OK, OK, We have injectors ready for the next phase, but not till Indy rolls an 11. If he doesn't do it soon, he'll be in timeout for 30 days. Back from the 'EAST' I see.
Old Aug 18, 2009 | 10:00 PM
  #492
tlcoll1's Avatar
Originally Posted by 9sec9
Ok, the jig's up fellas. "Two guys, two mods" - sure, sure. What you didn't mention was that you swapped in an automatic transmission. C'mon, fess up - no human can shift that fast!
Tom
Old Aug 19, 2009 | 09:06 AM
  #493
9sec9's Avatar
tlcoll1, you got us. Actually, I didn't check inside Jim's car, he does have contacts that I'm not aware of. If he's got one, I'd like to have one too.
Old Aug 19, 2009 | 10:03 AM
  #494
Indy Evo's Avatar
tlcoll1, Thanks, but I was pretty dead Thursday and Friday. The last time I was at the track was a month ago and I needed to get back into the groove. The 12.008 and the 12.07 were pretty lazy launches. The 12.03 was a 1/10 better. I'm trying different air gaps with the Quarter Master clutch to see what works for me and that takes time and passes. We are going back out tomorrow if the weather holds and if 9sec9 is available. Indy
Old Aug 19, 2009 | 10:47 AM
  #495
warp9's Avatar
Ive been following along and the anticipation is killing me This time its gonna happen Indy! What an amazing grass roots thread by Indy and Tom, good luck.
