Intermittent starting issues
Old Jul 2, 2009 | 02:03 PM
rEVoLed's Avatar
For the last week or so I've been running into this starting issue. I could see the fuel pump hump and see fp go up but the car don't crank nor does the starter click. I originally though it was the starter, took it out and had it tested. Autozone said it was fine. Put it back in, clean the battery terminal on the positive side. It started for 2 days straight and now the problem comes back this morning. I'm going to check the ground connection but I'm out of ideas. Any help would be great.
Old Jul 3, 2009 | 12:01 PM
gsrboi80's Avatar
Clutch Switch??
Old Jul 3, 2009 | 12:06 PM
GPTourer's Avatar
Sounds like starter solenoid to me. Sometimes they only not work when the car is hot, but okay when its cold.
Old Jul 3, 2009 | 12:08 PM
meckert's Avatar
dead spot on the starter--
Old Jul 3, 2009 | 03:12 PM
C_LosEvo's Avatar
yeah just have your starter check
Old Jul 3, 2009 | 07:24 PM
mmmmbst's Avatar
Veteran: Air Force
^he said he had it checked already. Its the connection of the thin wire going to the male connector on the starter itself. Cut off the junk OEM female plastic spade connector and replace it with a new spade connector. When you put it back together, tug on it a little bit to make sure the new connection is good and wont come apart. Sorry for the bad description, having a brain fart on technical names.
Old Jul 3, 2009 | 07:32 PM
Kilratio's Avatar
It's definitley the starter. I had this exact same problem. Went to the dealership 3 times before I said keep my car till you find what it is. 2 days later they said they said it finally didn't start and the the problem was the starter.
Old Jul 3, 2009 | 08:01 PM
mmmmbst's Avatar
Veteran: Air Force
If that wire isn't making a solid connection (i.e. loose or corroded) you will get no action from the starter. Its a pretty easy fix without breaking the wallet with ruling it being the starter itself. It needs a power source from the solenoid when you turn your key to tell the starter to engage.
Old Jul 4, 2009 | 09:23 AM
rEVoLed's Avatar
Thanks for the inputs so after having a friend of friend who is a diamod cert tech look t it, turn out to be a bad connection due to a corroded starter line further up the cable. Replaced it and everything is good so far.
Old Jul 6, 2009 | 06:28 AM
crazybaldhead's Avatar
Its not the starter if it was already checked. It is most likely the barrel switches where you put in your key. There is most likely a hairline crack which causes intermittent starting, had this problem on a seven. You can replace it with one from a junkyard lancer.
benIX
Aug 3, 2016 10:57 PM
turbotaloon95
Feb 10, 2016 07:47 PM
wazzelby
Jul 18, 2015 05:46 PM
Ekoy
Aug 3, 2010 11:48 PM
Darkn3s
Jan 4, 2010 12:31 PM
