Hazard light button doesn't light up
Old Sep 6, 2012 | 05:48 AM
samdog's Avatar
Originally Posted by Aar0nsite
i figured what the problem... but with that now i have a new problem...
well i took the hazard component out and i went ahead and took the bulb out... as i closely inspected the bulb... i could see that the filament inside of it were not making contact at all.... what does this mean? well the bulb is toasted.. so i need a new bulb...
does anyone know where i can find this bulb?
Radio Shack 272-1092 for $1.99. It is a 12v 0.7w bulb rated at 10000 hours life. Note how the OEM bulb flying leads are twisted into the gray base and then do the same with the new one.
Old Oct 20, 2012 | 08:38 PM
fugiwara's Avatar
To the OP, did you figure out what the problem is?
Old Oct 25, 2012 | 08:21 PM
CO_CReX's Avatar
I am also interested in finding out what the issue is. Mine doesn't light up and neither does my fog light switch. Are these powered by a fuse? If so, which one?
Old Oct 26, 2012 | 07:25 AM
eric06ix's Avatar
Have you checked to see if the bulbs are burned out? This was a very common issue with older Sentras, and the same part number as above, fixed it. The RS bulb might be a little shorter, but it will fit and you won't notice any difference in brightness.
phizzalot
Aug 30, 2012 01:49 PM
axiomstyles
Feb 27, 2012 11:41 AM
MitsuJDM
Apr 6, 2009 05:32 PM
TheShortBus
Lancer Troubleshooting
Jul 30, 2008 11:10 AM
dsm_mikey
Mar 5, 2006 07:50 PM
