Battery Replacement.. opinions OEM style
Old Jan 30, 2010 | 08:02 AM
  #61
mrfred's Avatar
Originally Posted by wntanEVO
FYI, Optima ret top, from what I remember, is a pound or two lighter than the original battery. I ended up using the Interstate Megatron Plus, MTP-35, which is actually a few pounds heavier than the original. I went with the Interstate because, here in Hawaii, it is always hot, and the Megatron Plus built to withstand high heat (MTP II is better, but they don't make it in our size and/or required dimensions). I also wasn't too sure if the Optima would fit, based on the online dimensions and my own tray measurements. Instead of ordering the Optima and having it not fit, I went with the Interstate. So far, I have completely drained the Interstate battery once (3 times on the original), but have been able to recharge it by jumping it and condition it with the Battery Minder. Now that I know the Red Top will fit, I will most likely try that or look at a Kinetik(previously mentioned). Once I move to a much colder area (soon), we will see how the Interstate holds up.
It also looked to me like the Optimas wouldn't fit in the stock tray. Also looked like the posts were too far in to work with the stock battery terminals clamps. Ended up getting a DieHard North Gold. Dropped right in, including the OEM battery cover.
Old Jan 30, 2010 | 10:30 PM
  #62
sleeperkid's Avatar
Just bought an Optima battery red top today cause my battery died, and the installation was terrible. trying to get the terminals to reach was a pain. Just thought I would share.
Old Jan 31, 2010 | 03:42 AM
  #63
SpoolinUp's Avatar
Silver Sponsor
You bought the wrong one. Sounds like it is a 35R. Most places stock the 35...
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jan 31, 2010 | 10:01 AM
  #64
migs647's Avatar
That's what it sounds like to me as well. I didn't have any issues with mine.
Old Jan 31, 2010 | 10:26 AM
  #65
tristat3's Avatar
i had a optima in my bmw once and it never failed me running upgraded speakers and a woofer in the trunk listening to music for 2 hours without the car even running just my 2 cents
Old Jan 31, 2010 | 03:31 PM
  #66
sleeperkid's Avatar
How would I know if I got the wrong one? The top says red 75/35 is there somewhere else I should be looking?
Old Jan 31, 2010 | 04:47 PM
  #67
4RETECH's Avatar
Note my earlier post.
Correct Battery is a 35. NOT a 75/35 as the terminals are backwards....
Return it...
Old Jan 31, 2010 | 04:54 PM
  #68
sleeperkid's Avatar
Alright thanks I guess I gotta bring it back, the person at autozone said as long it said 35 on top its would fit
Old Jan 31, 2010 | 05:05 PM
  #69
4RETECH's Avatar
Autozone guys, they don't know the measurements.
http://www.1st-optima-batteries.com/...Fd1L5QodV0ah3g
This is where I got the measurements.
Good Luck.
Old Feb 3, 2010 | 12:20 PM
  #70
vipevo9's Avatar
optima red top its better to just sometimes spend a little extra
Old Feb 3, 2010 | 07:05 PM
  #71
sleeperkid's Avatar
Update: So I bought the correct battery today and it went in easy and I was done in like 5 minutes, and I feel like an idiot. So advice for anyone about to buy the battery make sure its the 35 and not the 75/35.
Old Feb 3, 2010 | 07:18 PM
  #72
brianeclipse98's Avatar
I see that you already bought yours but i will throw this out there for everyone else. When i bought my car it had a mini battery installed...which completely sucked. I didn't have the room for a full sized yellow top optima with my icp. so with a little testing fitting i found that you can get a honda civic yellow top and it fits very nicely. Its' not much bigger than the mini i had before and has never let me down
Old Feb 3, 2010 | 08:11 PM
  #73
migs647's Avatar
I'd like to add...
You may have got lucky (didn't you buy from autozone?).
When I went to buy my yellow top from autozone, the manager was being a total jerk about buying it. I wasn't sure if it would fit correctly, and he said all sales final on optimas. I ended up buying from Amazon for 1/3 the price. When I put it in the bottom corner broke (good thing I didn't buy from AutoZone) and Amazon sent me a replacement without having to send the old one back. Make sure the place you buy your battery from will stand behind it.
Old Feb 3, 2010 | 08:16 PM
  #74
xmaciek82x's Avatar
I just bought a 75/35 and install was pretty simple. But then again I relocated it to the trunk
Old Feb 3, 2010 | 08:25 PM
  #75
GaBe511's Avatar
I will be in the market for a new battery soon so this post is great. The cold weather shows how weak my current battery is. I had a yellow top before in my crx, so the red top will be my first choice and since it fits and everyone seems happy with it then its a winner!
