high milage but built engine?
Old Jan 12, 2010 | 10:23 PM
kmc8302's Avatar
dont care for the new x, dont really care for my gts either. plus i have a evo 9 right now which i love, want another one.
Old Jan 14, 2010 | 12:06 AM
DubsE46's Avatar
goal 200k + running stronger than all the people with garage queens. i bought my car to drive it not have it sit in the shade collecting dust.
Old Jan 14, 2010 | 05:40 AM
gsrboi80's Avatar
Truth
Old Jan 14, 2010 | 05:51 AM
Davethewave's Avatar
Originally Posted by gsrboi80
Yea I wouldn't do drop ins at that point but a full engine overhaul with machining and such and yes your bottom end will be like new and ready to push big power.
After tanking, machining, painting, etc.... There is no difference between a 100k block and a 30k block
im wondering if the abuse put on a block has any effect on the structure and durablility of the metal in the block?
Old Jan 14, 2010 | 05:52 AM
Gordian79's Avatar
Originally Posted by TeStUdO
Rebuilding the bottom end with forged components would basically make it a new motor if your head is in good condition.
No it would not.Block is worn and will need machine work with oversize pistons.I dont want to hear car was babied 100k miles its an evo a performance car bought by gear heads so its been beaten on.Cylinder head has nothing to do if block is good or not.If(if it had less mileage) you do drop in rods and pistons you might as well have your head checked out have valves re lapped,check for straightness etc.Again at that mileage i would do full build.
Old Jan 14, 2010 | 06:21 AM
gsrboi80's Avatar
With an iron block like the evo I wouldnt think so. Could be wrong but I plan to use my block unless I launch a rod through it of course. She's at 120k about now. I def will have it fully machined the right way. Think about all the old 60's motors that get overhauled.
Old Jan 14, 2010 | 09:32 AM
b16a95eg's Avatar
Actually this usually makes them stronger. Back in the older days BMW used to go get seasoned blocks out of junkyards to turn into their F1 engines.
I wouldnt do just drop in pistons at this point though, i'd call the piston manufacturer, get the measurements on the pistons and their recommended Piston-wall clearance and see if you have enough room to hone, some forged pistons I've seen in the honda world required .002 more clearance than the stock bore. so you can keep the stock bore and have a decent hone job (not just glaze breaking)
so best bet find the exact pistons you want (dont buy just yet), get the measurements and piston/wall clearance recommendation from the piston manufacturer, take your block apart, bring it to a machine shop and see how much room you have to play with before having to buy .020 over pistons
Old Jan 14, 2010 | 11:05 AM
4RETECH's Avatar
Shoot, I'm trying to get my new turbo and intercooler in before I hit 200K..
Maybe next month
Old Jan 14, 2010 | 04:08 PM
Biggiesacks's Avatar
The reason seasoned blocks are stronger is because of all the heat cycles they go through. The constant heating up and cooling down strengthens the metal.
Old Jan 14, 2010 | 04:44 PM
oneofakindtrini's Avatar
Depends on the condition of your head and other components to the motor.. Cams, things like that.
Old Jan 14, 2010 | 10:43 PM
Gordian79's Avatar
Old Jan 14, 2010 | 10:56 PM
xRoguex's Avatar
100K the bores wont be as straight as they should be and you will just be asking for trouble.
You can do it once and do it right.
Or you can risk it and see if your luck holds out.
Mine did not.
Old Jan 15, 2010 | 09:07 AM
kmc8302's Avatar
i believe im going to take out the block, have ams work on it, then ill do a rebuild kit on it. forged pistons, manley rods, kelford cams, valve springs/ retainers. The whole 9 yards.
iLLevo_
Jul 27, 2016 10:17 PM
BubbaKush
Jun 19, 2011 06:51 AM
criptballer
For Sale - Cars For Sale
42
Feb 28, 2011 02:19 PM
evolved1
May 3, 2004 07:47 AM
raywong
25
Dec 2, 2003 08:52 AM
