clutch pedal adjustment
Old Jun 7, 2010 | 07:26 AM
rartist's Avatar
My VIII has a new ACT clutch and new everything that hooks up to it. It feels a lot lighter than what I'm used to. What should the clutch pedal adjuster be set to now; I had it most of the way out when my old clutch was on death's door. I was thinking of moving it back up to about 50% out.
Old Jun 7, 2010 | 07:37 AM
TeStUdO's Avatar
http://www.evomoto.com/tech_articles..._article_id=28
Old Jun 7, 2010 | 07:58 AM
rartist's Avatar
I know how to do it, I was wondering what it is from the factory.
Old Jun 7, 2010 | 08:02 AM
TeStUdO's Avatar
Try ~2" off the floor for engagement.
Old Jun 7, 2010 | 08:43 AM
monkey_187's Avatar
you should have a little play in the pedal before engagement, here is more info on it, I hope it helps.
https://www.evolutionm.net/forums/ev...djustment.html
Old Jun 7, 2010 | 09:52 PM
sweetGT3's Avatar
Agreed, the pedal adjustment is "personal feel".
I had a new clutch installed and the pedal felt way different at first (compared to the worn out original) however it feels "normal" now. Full engagement at 3/4 pedal.
Is this correct?
Old Jun 8, 2010 | 12:26 PM
09Ralli's Avatar
my clutch starts to engage pretty high when everything is warmed up, ive gotten use to it, but i heard it wasnt good to have it up that high to launch?
Old Jun 14, 2010 | 03:57 PM
rartist's Avatar
I was thinking about where the bolt is set on the clutch adjuster when it comes from the factory.
My new clutch and clutch gear has started making this noisy rattling sound when in neutral and the clutch is out, or when the clutch is out and in gear, driving. Push the clutch in and it goes right away. Don't know what's causing it, back to the shop tomorrow. It seems to lessen as things warm up.
Old Jun 14, 2010 | 05:35 PM
KaRboN's Avatar
Mine is low to mid,That is where i like it...You should def adjust it for your personal preference tho ! : )
Old Aug 6, 2010 | 06:08 PM
panem's Avatar
I set mine a tad lower than where it was originally. Mine rattles too and it's most likely the TOB being a little loose. I'm gonna set it lower so to tighten up the TOB later I'll let you know if the rattling stops
DOUGLAS
Sep 26, 2011 08:27 PM
clubEVO93
11
Jan 3, 2011 06:05 AM
vladdyyy
Evo X How Tos / Installations
Oct 6, 2008 07:28 PM
Johnboy1065
Mar 23, 2008 03:48 PM
VRamirez2004
Apr 20, 2006 01:51 PM
