Oxygen Sensor Wires Pulled
Old Jun 24, 2010 | 03:52 PM
fuzzychi's Avatar
When I was removing my oxygen sensor from the o2 housing it somehow got caught on the housing when the impact wrench started freely rotating the sensor. Is there any way to reconnect the wires into the connector or am I going to need to get a completely new sensor from Mitsubishi?
Old Jun 24, 2010 | 10:15 PM
heavens turbo's Avatar
if they got pulled out of the sensor, you need a new one. if the wires broke, you could splice them. good luck.
Old Jun 25, 2010 | 11:52 AM
20gmr's Avatar
I would replace it. narrow band o2's work off of very low voltage so any change in resistance of the wires can make the ecu interprit the wrong signal. check oxygensensors.com or pm CBRD they know the cheap place to get plug n play factory ones for much less.
Old Jun 25, 2010 | 01:46 PM
CBRD's Avatar
oxygensensors.com is the best,
get the plug and play.
cb
Old Jun 25, 2010 | 10:12 PM
fuzzychi's Avatar
Sweet, looks like I'll be doing that
Old Jun 25, 2010 | 10:22 PM
mifesto's Avatar
only if you do hackjob in reattaching or change the length of wire will you screw with the voltage it receives..... if you do good job resoldering, you may be alright
Old Jun 26, 2010 | 09:10 AM
fuzzychi's Avatar
I decided to just get a new sensor so I don't have to do any hack job
Old Jun 26, 2010 | 10:02 AM
SpoolinUp's Avatar
Silver Sponsor
Good call!
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
raidokoiv
Aug 24, 2019 12:07 PM
brandon1304
41
Jul 19, 2012 08:05 PM
Nicker09
Lancer Troubleshooting
23
Jun 24, 2010 09:18 PM
KevinO
Dec 4, 2009 08:38 PM
mostro
Jan 27, 2007 03:55 PM
