what valve spring compressor?
Old Oct 20, 2010 | 01:51 AM
EvoJoeIX's Avatar
Can someone who has changed their valve springs post up what valve spring compressor tool they used? I don't want to buy one and have it give me problems or not fit right. I'm talking about the type that you don't have to pull the head off to use also
Old Oct 20, 2010 | 04:43 AM
Phantom EVO's Avatar
Snap-On part#: YA9140A
Its actually labeled Blue Point, but Snap-On makes and sells it. Its $185, well worth the money after fighting other compressors designed for V8 style cylinder heads. This unit easily bolts down to the cam journals and runs down a bar so you can do one whole side without having to remount the tool.
Old Oct 20, 2010 | 05:05 AM
black95tt's Avatar
This one works nicely.
http://www.euroexportinc.com/store/t...ompressor.html
Old Oct 20, 2010 | 05:19 AM
meckert's Avatar
Well, now that you know what kind to use if you don't pull the head--anything else will work if you do take the head off..
Old Oct 20, 2010 | 05:40 AM
Bobster22388's Avatar
Originally Posted by black95tt
This one. I have used it myself and it works great. Make sure you get the adapter for the Evo's though, it's a tad bit smaller than the 1g heads. It will work either way. It does take a while to do, but if your not pulling the head this is about as easy as it gets I believe.
Old Oct 20, 2010 | 08:04 AM
EvoJoeIX's Avatar
How do you keep the valves from falling into the motor when you pull the spring and retainers off?
Old Oct 20, 2010 | 08:25 AM
black95tt's Avatar
Pressurize the cylinder with air via the spark plug hole. This pressurizes the combustion chamber and keeps the valves from falling in.
Old Oct 20, 2010 | 09:15 AM
+1, and make sure the engine is at TDC to make sure none of the valves are open.
Old Oct 20, 2010 | 09:16 AM
srtboostin22's Avatar
Joe call me..
Rob
Old Oct 20, 2010 | 10:42 AM
EvoJoeIX's Avatar
That's what I thought. Thanks for all the help
Old Oct 21, 2010 | 08:09 AM
Steve_P's Avatar
here's another universal one that reportedly works well on the 4G63. Looks similar to the Snap On
http://www.tooltopia.com/schley-91400a.aspx
Old Oct 21, 2010 | 10:41 AM
ESTIB1's Avatar
i bought this one and it worked fine
Old Oct 21, 2010 | 11:32 AM
sobo's Avatar
I second this. Excellent tool!
Old Oct 21, 2010 | 06:50 PM
wht95scort's Avatar
No valve's will be open regardless of it being at TDC because there will be no cams in there But its a good Idea to rotate the crank to TDC on each cyl you are removing the springs on. This way if you lose air for some reason the valves wont fall into the cylinder.
ptm5070
Jun 12, 2015 07:56 AM
thepoint4life23
For Sale - Miscellaneous Automotive
May 15, 2015 10:21 AM
kevvmann_
Lancer Engine Tech
Mar 8, 2015 06:45 PM
Slo_crx1
15
Oct 2, 2011 03:35 AM
Sephitrask
Feb 17, 2009 09:20 PM
