New Full Blown 70mm cast TB
Old Nov 13, 2020 | 05:49 AM
  #271
detroit pistins's Avatar
I don't think you can use EGR with these aftermarket throttle bodies. You may simply need to swap it back to stock.
Old Nov 13, 2020 | 08:10 AM
  #272
Evo9_Dubai's Avatar
You can't use the EGR. Also be careful, they break easy.
Old Nov 13, 2020 | 08:27 AM
  #273
Biggiesacks's Avatar
It's been a little while since I've looked but AFAIK the actual EGR gas passages are in the intake manifold. So all you would need is to source the vacuum for the control mechanism yourself to get it working. You will need pre and post throttle vacuum sources as pictured here. You could add a port to your Upper intercooler pipe just before the throttle and then grab vacuum from the manifold.
shangai
Jul 24, 2017 12:14 AM
rotterdam
Outlander Sport
16
Mar 18, 2017 06:30 AM
FreakEVO
Nov 5, 2016 02:55 AM
Speedlimit
EvoM Announcements
Jul 15, 2016 08:24 AM
Fookster
Jun 30, 2016 10:48 AM
