New Full Blown 70mm cast TB
Old Nov 3, 2013 | 08:14 PM
  #226
detroit pistins's Avatar
I think I have posted this in a different thread, but this is my theory wrt breaking the lip on the TB.... I think its due to using smaller tbolts. Eitherway...I hope FB do the right thing to their customers.
Old Nov 3, 2013 | 08:36 PM
  #227
Erik@MIL.SPEC's Avatar
Originally Posted by wjamyers
I had idle issues all of a sudden a few months back. I fixed them, mostly, with a new IAC motor but it took the ECU a few hours to learn it. People told me to adjust the BISS. Never got 'round to it. I still can't just hop in and drive on a cold morning or it might sputter and die, it even happens in the middle of the day sometimes, jump in, start up and give it a few seconds and it's alright. I have no idea how long my TB has been crushed. It was driving alright. there were some issues, it would "pop" sometimes when getting on the throttle.
I don't hear anyone having any problems with the mil.spec unit. I'll do some more research but likely just going to do that.
I haven't heard of any issues with our TB's in a long time. PM me with any questions.
Old Nov 4, 2013 | 09:44 PM
  #228
wjamyers's Avatar
can any other knowledgeable people weigh in on whether I'll have problems putting a 65mm TB on a 70mm plenum?
MAPerformance who sold me the IM/TB combo?
should I consider getting my IM modified by somehow putting material back and smoothed out?
I don't know if FBM will help me out but I also don't want to have to stress about using t-bolt clamps on my TB going forward.
I guess I could just try it and if it causes problems deal with them then. I've read here that you want the two port-matched. Can any machine shop add material and then port match? MAP?
Never mind.
Old Nov 5, 2013 | 10:34 AM
  #229
wjamyers's Avatar
anyone? bueller?
Old Nov 5, 2013 | 11:17 AM
  #230
PureDrivePerformance's Avatar
Sure wish I'd just gone Mil.Spec from the get go. I searched for any issues on their TB and found only one but did find a number of people whose TB problems were solved with Mil.Spec seals.
I can't see where you will have a problem. The stock IM flange is 60mm. Right after that it opens up. Your set up will just eliminate the 11mm step that the stocker has.
The only concern I'd have is if the TB surface is flat. When you weld a flange on the IM it needs to be milled due to the high heat of welding.
Here is a pic of my FB on a stock IM. You can see the step. I'd consider this a problem. FB does too, that's why they include a stepper that goes between their TB to a stock size IM.
Also including a pic of the IM step that opens up.
Old Nov 11, 2013 | 03:37 PM
  #231
wjamyers's Avatar
"unfortunately, due to the timeframe of the purchase they are not willing to do anything to help out on that" - Vender's response when I asked them to coax Full Blown to do the right thing.
I don't think the timeframe of the purchase is in anyway relevant except as an excuse to not back up this obviously defective part. NO ONE else's throttle bodies get crushed by t-bolt clamps. These units are trash.
Full Blown Motorsports is not an ethical and forthright manufacturer and has lost my business, permanently, I don't care if they come up with the second coming of the turbo charger, I'll never purchase anything from them ever again.
Old Nov 12, 2013 | 11:31 AM
  #232
wjamyers's Avatar
Yesterday I decided to try to help other people from suffering the same fate as me and I put up reviews ...
At Full Blown Motorsports (not yet published):
http://fullblownmotorsports.com/full...-throttle-body
MAPerformance (published):
http://www.maperformance.com/mitsubi...0mmtb-evo.html
LancerShop (not yet published):
http://www.lancershop.com/customer/p...productid=5955
Amazon (published):
Amazon.com: Mitsubishi Evo 8-9 Full Blown Cast 70mm Throttle Body: Automotive Amazon.com: Mitsubishi Evo 8-9 Full Blown Cast 70mm Throttle Body: Automotive
Today I realized that most of the rest of you have not done so (you can't have, since I was the first or second person reviewing it in all 4 places.)
So why don't you guys go and add your own reviews so that maybe the next poor dumb sap won't get screwed the way we were?
I updated or added all the reviews with this:
"A year and a half after I bought it, after experiencing the last 6 months of idle problems, I went to clean it and found the inlet crushed by the t-bolt clamp connecting the UICP.
It turns out I used the wrong size t-bolt clamp (3", 79mm/87mm) and it crushed it. Make sure you use the right size T-bolt (2.75") or just use a worm!
This throttle body was mostly like stock during it's life except for a chronic stickiness that would cause it to jump when trying to roll on the throttle. This was pretty annoying and caused you to modify your driving style but other than that it was a good unit. If not for that I would have given it 5 stars. "
Old Nov 12, 2013 | 12:56 PM
  #233
blackgsx01's Avatar
I dont understand why FB would cover it if the customer used the wrong size Tbolt clamp
Old Nov 12, 2013 | 01:10 PM
  #234
blackgsx01's Avatar
Amazon (published):
I dont understand why your out to try and ruin the reputation of FB? I did a simple google search for the throttle body and there are multiple posts on not to overtighten the tbolt clamp or you could crack it. Why would FB cover there TB if its something the OP did? Its like running STMs Alum intercooler and overtightning the tclamps and crushing the pipe which is easy to do and then blame STM for making to thin of a intercooler pipe.
I have always used a sticky/tacky compound (even utra hold hairspray) and sprayed it around my pipes so I wouldnt have to tighten the tbolts nearly as much as I would without it and I hold 40psi without issues.
Im not taking sides, Im just looking from a vendor prospective on why they would cover a cracked lip on a TB when the OP overtighted it or used the wrong size tbolt.
There are plenty of people running the TB without issues
Old Nov 12, 2013 | 01:34 PM
  #235
wjamyers's Avatar
Are anyone else's throttle bodies cracking like this? Answer the question... yes or no?
Old Nov 12, 2013 | 01:38 PM
  #236
wjamyers's Avatar
You know that for a fact, do you?
If you know that, perhaps you can tell us whether Full Blown Motorsports are even slightly interested in finding out what size clamp anyone used? Because if they are, that's the first I've heard of it.
[EDIT] That's a very good point and I did indeed use the wrong size clamp (3", 79mm/87mm)
Old Nov 12, 2013 | 01:44 PM
  #237
Just to clarify, the OP didn't overtighten the TB as he sold me his BNIB.
I posted on post 177 that I cracked it. I reread what I posted and it reads like I tightened it snug then did 2 to 3 more full revolutions of tightening it down. That's not what I did. I may have tightened it 3/4 of a turn in 1/4 turn increments after I snugged it down.
It cracked right at the casting mark. I showed it to FB and they offered me a discounted BNIB, but weren't interested in an exchange. Fair enough. I decided that I will weld on a 3" ID aluminum tube with a thicker wall with a lip.
I agree on TB and all IC piping is to use hairspray on the pipe to coupler contact like you recommend.
I've tightened my stock TB much tighter than I did this TB, but I learned a lesson. As detroit pistins pointed out it may have been too small a T-Bolt. IDK as I've never had this problem before with any T-Bolt.
Old Nov 12, 2013 | 01:56 PM
  #238
boostedwrx's Avatar
My FB TB cracked. Back running ported stock. Idle is better too.
Old Nov 12, 2013 | 02:23 PM
  #239
Nice!!! Is that with your FP Black?
I'm on the ported stock TB and IM kick. We're selling the MIL.SPEC 65mm TB because of this. I would have sold aftermarket TB, but at this point I think the ported stock is the way to go for most applications.
For big time HP, I think you may have to sacrifice a little and go with big IM and TB.
Old Nov 12, 2013 | 03:20 PM
  #240
wjamyers's Avatar
go put up a review.
