New Full Blown 70mm cast TB
Old Mar 27, 2012 | 08:15 PM
  #181
10isace's Avatar
I contacted Full Blown & MAP. FB and I are emailing back and forth now. I hope there is something we can work out.
I took it to my fabricator and he said it's kind of hard to weld cast aluminum to aluminum tube. My thought was to cut off the inlet part and weld on an aluminum tube with a lip.
I might try JB weld if FB can't do anything. Lastly I'll have my fab person weld on an aluminum tube.
Old Mar 28, 2012 | 12:32 PM
  #182
4g63evoeight's Avatar
no reason they shouldnt replace it..
anyways, are the gains from with the adapter plate that are posted on MAP's website?
Old Mar 28, 2012 | 04:55 PM
  #183
10isace's Avatar
Yes, it was with the adapter plate. However, I had a boost leak at 2 spots on the stock TB. So its not an accurate gain.
Old Mar 30, 2012 | 10:34 AM
  #184
10isace's Avatar
UPDATE: ok, it's been a couple of days and I haven't heard back from Full Blown. I put in an email yesterday to see what there verdict is. I'll let you all know.
Old Mar 30, 2012 | 10:56 AM
  #185
ct9asilver's Avatar
That TB is so cheap that I would just another one, or get the Skunk2 68mm or even better yet stay with a Mil.Spec 65mm OEM TB.
The cast tb was bound to break cranking down on it with a T-Bolt clamp you can oval SS IC pipes with a T-Bolt clamp what do you think will happen to cast aluminum....?
Teflon tape on the bolts is not really good of an idea as this below, I've used it for years on lower heat engine parts and it works like a champ, instead of using some crap plumbers use.
http://www.permatex.com/products/aut...ad_Sealant.htm
Old Mar 30, 2012 | 01:00 PM
  #186
10isace's Avatar
Cool, thanks for the advice. I read there were boost leak problems with the Skunk2 TB. I think I'll do the Mil.Spec.
Old Mar 30, 2012 | 02:31 PM
  #187
ct9asilver's Avatar
The skunk hasn't had leaks since 2009
Old Apr 2, 2012 | 06:52 AM
  #188
10isace's Avatar
Still no response from Full Blown. I hate it when a company can't get back to you. I'm sure they're trying to figure out what to do, but a response would be nice CS.
Old Apr 2, 2012 | 02:44 PM
  #189
10isace's Avatar
OK, finally heard back from Full Blown Motorsports. Basically, it's not warrantied due to over-tightening. I kinda of figured that. I didn't really feel like I over did it, but I guess that's the double edge sword with those t-bolt clamps (BTW, I'm using a worm clamp on the stock TB now and for now on any aluminum cast parts.).
Full Blown was nice enough to sell me a new one at a discount. I'm considering it. I'll have to sleep on it.
Old Apr 2, 2012 | 03:38 PM
  #190
10isace's Avatar
That's good to know. I just saw your set-up on another thread I'm thinking this may be the best route, S2 IM & TB.
Just saw this on S2 website. Sorry it's
http://youtu.be/9cjiz1TZKI0
Old Apr 11, 2012 | 10:12 AM
  #191
10isace's Avatar
I asked FullBlown if they had any defective ones that I could get and rebuild it with my parts, but they said no. So it looks like I'll take it to the welder after I take it all apart (seals, sensors, etc.). Or maybe this will be my first welding job. Whatever happens, it was certainly a learned lesson.
Old Apr 11, 2012 | 02:45 PM
  #192
vmrevo9's Avatar
Veteran: Air Force
i cant believe that FullBlown isnt really helping you out with this. normally you would think that the first break from their TB they would work with the customer.
i have thought about the FB TB but it looks like either the ported OEM or a skunk 2 would be better options.
Old Apr 11, 2012 | 02:53 PM
  #193
10isace's Avatar
I can't say that I'm particularly happy about this. I honestly think it could have been a weak point in the sand casting. But who knows. Anyhow, the Skunk2 TB and IM setup looks really good to me right now.
You would think they would want me to send it in. Other companies I've dealt with like to see what's going on first hand. Maybe mine wasn't the first to break.
Old Apr 11, 2012 | 03:03 PM
  #194
vmrevo9's Avatar
Veteran: Air Force
its a possibility that it isnt the first to break but it's sad that FB isnt really helpful. good luck!
Old Apr 11, 2012 | 07:04 PM
  #195
blknblubkrdude's Avatar
Anyone run the FB 70MM with ETS short route UICP/IC?
I was using the stock route ETS UICP with the OEM TB no problem.
I now am installing the short route to the 70mm TB and it's not fitting so well. I'm wondering if the extra length on the TB is screwing with me.....
