New Full Blown 70mm cast TB
Old Mar 7, 2012 | 05:30 PM
  #151
n2oiroc's Avatar
Originally Posted by 03BoostedVIII
anything over a 65mm throttle body and your just wasting your time/money. Its not gonna make any real noticable difference
maybe, even if that was true you can buy this one for the cost of getting the stock one reworked and sell the stock one and end up money ahead.
Old Mar 8, 2012 | 03:52 AM
  #152
10isace's Avatar
Originally Posted by blknblubkrdude
For most power levels a 65mm is just fine.
There is a certain CFM where switching to 70mm would be beneficial.
Why not do it right the first time and only have to buy 1 part... which just so happens to be at the same price point and cleanly deletes the EGR/Coolant ports.
^Agreed! I just purchased a stock IM that I'm going to port to match my FB 70mm TB. I am estimating a 5-15 hp increase with my mods. The one thing I don't quite fully understand is if the 2.5" ic piping diameter will be a restriction. Assume I have enough flow to justify it, would a 3" piping/3" inlet and outlet FMIC free up more power? I'm assuming yes. I think I need to do some testing.
Old Mar 8, 2012 | 09:41 AM
  #153
fireroasted's Avatar
^^^^^ I am wondering the same thing. I have the 70mm from the MAP rev3 purchase. I ported the head and exhaust mani myself, and am also wondering if I need bigger IC piping. I have the ETS 3.5 on order but still the smaller piping too. Just haven't done any research/shopping for the piping, because I didn't have the tank (particularly the end tanks in hand yet. The TB looks like it can swallow a watermelon
Old Mar 8, 2012 | 03:15 PM
  #154
03BoostedVIII's Avatar
Very true lol always nice to have a little extra money
Old Mar 8, 2012 | 03:50 PM
  #155
Blue91lx's Avatar
3" IC Piping will hinder spool and not really benefit under ~700whp. 2.5" is plenty fine. TBs are a "last resort mod" to me, as the hp/$ ratio is hideous.
Old Mar 8, 2012 | 04:57 PM
  #156
n2oiroc's Avatar
i agree, i mostly bought mine because the stocker was leaking and i didnt feel like fixing it and the full blown is just a lot cleaner looking with the lack of ports and barbs.
Old Mar 8, 2012 | 04:59 PM
  #157
LI Pinky's Avatar
I bought one and love it, not to mention it's just pretty looking lol
Old Mar 16, 2012 | 09:51 AM
  #158
RJones's Avatar
Has anyone had issues with a high idle w/ this tb? I've got the set screw loosened all the way, and the idle is still around 1300-1500.
Old Mar 16, 2012 | 04:50 PM
  #159
blknblubkrdude's Avatar
Sounds like a large vacuum leak to me.
If you have the ability to do a boost leak test, do that first thing.
That will more than likely expose your problem.
Old Mar 16, 2012 | 05:12 PM
  #160
RJones's Avatar
I'm definitely planning on doing a boost leak test, but on second thought I think it's TPS related. I datalogged and at idle it's at like 19% instead of the usual 13.3%
Old Mar 16, 2012 | 05:18 PM
  #161
My tps at idle from the factory was around 16%. If your TPS reads 100% @ WOT, and not a millimeter sooner, I would not suspect the TPS to be the culprit. Stranger things have happened, though.
Old Mar 16, 2012 | 05:33 PM
  #162
RJones's Avatar
Hmm mine has been at 13.33% every time I've ever logged my car, so seeing it at 19-20% throws a red flag for me. I'll try to log for wot too and see where it lands. One guy in another thread said that the tb flange on his rev3 manifold was warped so badly that you could see daylight. So I'll have to check that too.
Old Mar 16, 2012 | 10:07 PM
  #163
RJones's Avatar
Sure enough, when I went home and logged the car in the off position, it was at 19.2% and reached 100% before the butterfly was fully open. I adjusted the TPS until the readout was 13.33 (repeating of course) and idle is fine now.
Old Mar 17, 2012 | 12:54 PM
  #164
vmrevo9's Avatar
Veteran: Air Force
good to hear!
Old Mar 25, 2012 | 07:35 AM
  #165
10isace's Avatar
I felt like I had a boost leak. Drivability, rich afr's, etc. Anyhow, I found some leaks, but this one has got me stumped on what to do now. Here's a vid:
